Just found out that the law doesn't require me to have a cat. so I've decided to get some pipe and make a few flanges. Anything to look out for when i'm doing this? i know there's currently a temp sensor but i just want to cable tie it out of the way for now.
Also, will this give the car a better sound? as it already has a nismo 3" exhaust. is the cat holding me back from a better note?
Cheers
http://www.youtube.com/watch?v=bsIrz_LaHdo
https://www.sau.com.au/forums/topic/406140-de-cat-advice/
Pretty sure the law says you need a cat !! If the car came from oem that way , your not going to feel a lot of power over a hiflow car , only noise that makes it sound faster
A decrease if your cat expands pipe goes from 2.5 ,3 to 5in the air turbulence actually makes less power
Plus smells like hell to idle
The fine is huge if your not running a cat or shop removes it for street use
After running no cat on NA rx7 for 11 yrs except for 15 min california style emissions test only to remove it again , on that full race motor i noticed it a lot but the factory intakes etc had to be put back on to pass too and a bottle of emmisions pass junk poured into the tank for the test on bridgeport motor
Its not worth it buy a 100cell for 200 bucks which is sorta legal anyway
Can be drone at speed which is super annoying
My 2 c
https://www.sau.com.au/forums/topic/406140-de-cat-advice/#findComment-6471385
I gutted my 3" cat and felt and heard no difference. Kakimoto 3" exhaust.
But there was the occasional bang of a back fire changing gears or just backing off the accelerator.
And yeah I'm pretty sure by law you need to run a cat. I think if the car is pre '85 (or somewhere around there) then no hotdog or cat required, just mufflers.
https://www.sau.com.au/forums/topic/406140-de-cat-advice/#findComment-6471431
Carbon 34,
OP is from NZ - cats are not a requirement there, I'm lead to believe.
I thought the same thing, but I believe this has been revised.
http://www.transport.govt.nz/legislation/Vehicle-Emissions-Questions-and-Answers/
https://www.sau.com.au/forums/topic/406140-de-cat-advice/#findComment-6472514
Cheers for the input, the car is registered as a special interest vehicle (used to exempt cars from NZ regulations on frontal impact and emissions) which the R32 GTR classes as.
The car sounds quite droney already and it does occasionally spit when on the overrun and changing gears, see what the story is on the weekend.
https://www.sau.com.au/forums/topic/406140-de-cat-advice/#findComment-6472518
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
