Hey guys,
I'm new to the turbo scene and I'm looking to upgrade my stock snail. I've looked on the SAU fourms for some opinions and also asked some friends with skylines but not really getting any clear advice yet.
Here is the current setup to the best of my knowledge:
1995 R33 GTS=T Series 1.5 RB25DET
Mods:
2.5 inch exhaust w/ dual 2 1/4 inch tip
frontmount intercooler
frontmount oil cooler
oversized radiator
bosh electronic fuel pump (rated to 650hp)
bigger injectors (not sure which ones)
Greddy e-01 boost management
4" pod filter
Z32 AFM
Hicas lock bar
Splitfire coilpacks
Lightened flighwheel
Heavy Duty Clutch
Front strut bar
Slotted and cross drilled front disks w/ ultimate pads
after ive chosen which turbo to upgrade to I'm also going to install a nistune chip on the z32 ecu.
So guys what do you think is my best bet for a new turbo. looking to spend about $800-$1000 not much more.
Also one of the guys on here have offered me a T04E for $750 with dump pipe and external gate. Is this any good? and is it a good price for a used turbo?
Thanks guys.
https://www.sau.com.au/forums/topic/406250-rb25det-turbo-upgrade-help/
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
