Sau Vic 2012 Motorsport Championship Round 6 - Winton 1St Sept
I'll be heading off at 3pm myself,
we usually stay at top of the town in Benalla
If i remember correctly, top of the town was a titty bar on king street in melbs. If benalla provides accomodation too, you might find me stuck at the bar instead. :3some:
  • Replies 156
Posted Images
hey just reading the regulations on this one as its a bit different to the usual WRX days. Has anyone done these Victorian SuperSprint Championship days before? Is there anything specific that needs to be done to comply for our cars?
"Each competing vehicle is required to carry the CAMS logo" do they provide these or what??
I think they normally work on 80-90%
thier Winton round this time last year had 36 from memory they lost something like 5K from it.
thus running a round of the Cams championship this year thinking numbers would go up..not working so far.
Gee whiz, doesn't look good so far for the WRX club
I'm getting a mate to do a quick compression test on myengine this weekend to make sure the car is sort of ok to head up to Winton.
Will put in my entry the following week
Engine will be fine. I'll be rocking the GETZ, so can easily flat tow you back to Melbourne if anything happens... :|
http://www.vssc.com.au/Championship%20Results%20Outright%20after%203%20Rounds.pdf
Theres lots of cars who have participated in VSSC this year so maybe it will fill up quickly from here. sent mine on the weekend :D
entries updated, looks like a good day for track time.
entry list
http://www.wrx.com.a...5d279fca6364e6d
so what time do you reakon that speads will do around Winton?
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
