Guys,
Have noticed when I do long trips in stagea every now and then my boost will.go from 9/10 pound to getting restricted to 5pound till I reset ecu via turning off car. No dash warning lights and yes they work. Any ideas guys??
Edited by joshm35
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/
I had a problem with the Boost Solonoid where instead of getting 13psi max boost I would get only 7psi.
My problem had no CEL light and was solved each time by turning the car off and restarting. The cause always seemed to be giving it a few revs up a particular hill.
I changed my Boost solonoid and the problem was solved. The Boost solonoid sits on the passenger side of the car under the plastic engine cover. It is bolted to the side of the plenum and has 2 small rubber hoses running out one side, 1 to the intake and 1 to the turbo actuator and one hose rinning to the front of the car that connects via a T piece to the boost sensor on the intake.
I believe you can clean a solenoid but I did not try that.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478256
If the solenoid is blocked it will lower the boost, if there is a leak it may go higher causing the ecu to pull it back.
The hose from the solenoid that T's into the boost line has a restrictor in it. If it has been replaced that could make the boost rise too high causing the same issue. Have you changed the exhaust to 3 inch? that would cause it to run higher too.
A way around it is to trick the stock map sensor into thinking the pressure is fine, you could use a small pressure regulator if you wanted, set to 12psi, but I would be getting a better boost gauge first.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478291
i removed the factory one and replaced it with a turbosmart easy 5 mins fix. Boost comes on much better and smoother now.
QFT.
Buy boost gauge
replace with a turbosmart(or the sort) set it to 14psi or whatever the boost setting is and bypass the lines for the standard solenoid. Leave the standard one plugged in to avoid CEL. problem solved.
Edited by Sunkist
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478382
Cheers
Andy
This sounds exactly whats going on. Do you know the price and numbers of a new solinoid?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478525
Standard hoses and exhaust
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478527
for now? its what I would be doing permanently.. keeping or replacing the solenoid is not going to fix the factory safety drop in boost. it is spiking with the cold weather and/or not allowing the car to warm up before boosting. mine used to do it all the time and it pissed me off. the only way to get around it is by bypassing the solenoid with a manual/electronic boost controller.
once again: problem solved.
plus i cant imagine the worth it:price ratio for a new solenoid, which is most likely not going to fix the issue.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478798
No, don't know the cost. BUT either take up Scotts offer or get an aftermarker boost controller. Even with the wastgate actuator spring Mod the car felt stronger on initial boost when I used the Greddy Profec B boost controller. It bypasses the factory one so no more problem.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6479728
yeah i thought of keeping it though it's one less thing i gotta worry about second guessing me bleed valve :)
Just keep it in the glove box or boot hiding spaces, if the problem ever occurs plug it in and drive home?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6481080
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
