  • Replies 139
Ring [cabin] and ask for Damien, he'll tell you - I understand that they are confirming up like Wed/Thurs/Friday - via e-mail
Tickets are to be collected at the gate !~
ThanX B-Man.. Already rang them 2day. Said they have my form but I was getting a little twitchie...
Nice work on the clutch
Sam, Majanal (Dan) will be there in the morning and I think he'll be able to take your membership form...
But it would probably be best just to mail in the form and Shell (our fearless secretary) will process it for you!
Yep fried it bad - let it slip off the line and it just kept slipping - too much power - well that my excuse anyway :D:) ha ha
Yes it was a HD single plate - I now have extra super duper HD Xeddy with stonger PP clamping pressure :)
I will be there in the morning, I will have a few membership forms with me and will be able to collect money and forms up untill about 10:30-11am at the latest. (have to get to rugby)
Cheers,
Dan.
I won't be doing 11s ha ha ha
The car is prolly capable of it with the right driver - but this is only my second time out and you saw the aftermath of my clutch 1st time out.
I'll be taking it easier and gradually building up (down) my times.
Look out for me and come up and say Hi !
Click here to see pics of my car
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
