Been chasing an intermittent idle issue now for a while, and just got an ECUtalk lead and software for the laptop... Set it up in the car, found ignition timing was showing a solid 15deg at startup, but after about a minute or so running, timing started jumping around constantly between 0-10 deg on idle. Everything else was reading pretty steady apart from O2 voltage which i think is supposed to jump around between 0-1v and it was, so normal? Ignition timing held pretty steady when high in the revs apart from the occasional blip of a couple of degrees either way, but back to jumping all over the place between 0-10 as soon as the throttle is let off and back to idle.
So is this pretty conclusive then, that the CAS is rooted? Or could it be just indicating something else to be checked, before I go spend a fair chunk of cash on a new CAS?
  • Like 1
https://www.sau.com.au/forums/topic/407076-rb25-idle-now-cas-issue-advice-pls/
Standard ECU I'm guessing?
Reset the ECU and let it idle/take it for a drive and see if that changes anything
Also does the CAS sound/feel wrecked? Mine was making a slight grinding noise when it died, I pulled it off and could barely turn the shaft. Went one step further and pulled it apart, found that the bearing at the very front of the unit was dry as
timing should not be 0 at idle or even 10. 15-20 degrees is about right
yep, standard ecu. It's been reset many times since this first started happening, hasn't helped.
Pulled cas off this morning, felt ok, maybe slight roughness of bearing but not much. Can hear a bit of rumbling sound from that area while the car is idling though.
LOl i know 0-10 is not right :P that's why I mentioned it. Timing is set to 15deg though, and showed as this when first started yesterday, sits on that when the car is running right too...it's just the issue is getting more and more frequent. Also noted when out driving yesterday, when coming down in revs back to idle, it occasionally locks on a steady 20deg which makes it idle at around 1200rpm. A blip on the throttle brings this back down to a more normal idle, although with erratic 0-10deg timing.
i should also point out, timing is erratic only with TPS connected. When unplugged it idles at a steady 15deg, but jumps around once plugged in, TPS voltage readings are fine though and steady, not jumping about. Have tried another CAS and same result.
  • 4 years later...
My experience is that the timing will do exactly as described when the idle screw is set too high.  The ECU tries to control idle speed with reduced timing.  The first test is to wind in the idle screw and see if the timing starts to come back.  In my car, after a number of other issues were dealt with, I had to wind the idle in about 5 turns before the ECU gave up trying to pull the timing back to 0-5°.
Yes, was afm needed cleaning. As far as ignition timing goes, gtsboy is correct again lol. Timing is supposed to be erratic but having idle set right without idle control on, makes it less so.
allright thank you i will try to set my idle lower, but its 850 right now and ecu screw is in factory position. and iw cleaned afm and the volts seems to be right checked it with consult 1.14 at idle and i think they went around 4 when pulling hard at second.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
