Been chasing an intermittent idle issue now for a while, and just got an ECUtalk lead and software for the laptop... Set it up in the car, found ignition timing was showing a solid 15deg at startup, but after about a minute or so running, timing started jumping around constantly between 0-10 deg on idle. Everything else was reading pretty steady apart from O2 voltage which i think is supposed to jump around between 0-1v and it was, so normal? Ignition timing held pretty steady when high in the revs apart from the occasional blip of a couple of degrees either way, but back to jumping all over the place between 0-10 as soon as the throttle is let off and back to idle.
So is this pretty conclusive then, that the CAS is rooted? Or could it be just indicating something else to be checked, before I go spend a fair chunk of cash on a new CAS?
  • Like 1
https://www.sau.com.au/forums/topic/407076-rb25-idle-now-cas-issue-advice-pls/
Standard ECU I'm guessing?
Reset the ECU and let it idle/take it for a drive and see if that changes anything
Also does the CAS sound/feel wrecked? Mine was making a slight grinding noise when it died, I pulled it off and could barely turn the shaft. Went one step further and pulled it apart, found that the bearing at the very front of the unit was dry as
timing should not be 0 at idle or even 10. 15-20 degrees is about right
yep, standard ecu. It's been reset many times since this first started happening, hasn't helped.
Pulled cas off this morning, felt ok, maybe slight roughness of bearing but not much. Can hear a bit of rumbling sound from that area while the car is idling though.
LOl i know 0-10 is not right :P that's why I mentioned it. Timing is set to 15deg though, and showed as this when first started yesterday, sits on that when the car is running right too...it's just the issue is getting more and more frequent. Also noted when out driving yesterday, when coming down in revs back to idle, it occasionally locks on a steady 20deg which makes it idle at around 1200rpm. A blip on the throttle brings this back down to a more normal idle, although with erratic 0-10deg timing.
i should also point out, timing is erratic only with TPS connected. When unplugged it idles at a steady 15deg, but jumps around once plugged in, TPS voltage readings are fine though and steady, not jumping about. Have tried another CAS and same result.
  • 4 years later...
My experience is that the timing will do exactly as described when the idle screw is set too high.  The ECU tries to control idle speed with reduced timing.  The first test is to wind in the idle screw and see if the timing starts to come back.  In my car, after a number of other issues were dealt with, I had to wind the idle in about 5 turns before the ECU gave up trying to pull the timing back to 0-5°.
Yes, was afm needed cleaning. As far as ignition timing goes, gtsboy is correct again lol. Timing is supposed to be erratic but having idle set right without idle control on, makes it less so.
allright thank you i will try to set my idle lower, but its 850 right now and ecu screw is in factory position. and iw cleaned afm and the volts seems to be right checked it with consult 1.14 at idle and i think they went around 4 when pulling hard at second.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
