Osiris is good for whatever you can get a AFM to read. Has been used on cars with over 1000hp (USA)
With an AFM upgrade it will do everything that the HKS kit will do on a std motor. Without boost control, you dont even need to upgrade the stock AFM.
Also HKS FCon is available.
  • Replies 80
got most shit sorted plugs etc.
thinking about using royal purple oil and filter. its not cheap but is it worth it?
also turbo timer HKS or Apexi?
any recoms on electronic boost controller?
what about deleting the cat?
cheers :no:
Go Motul 300v or NEO. Both are better than RP.
No turbo timer - not required. Just drive comfortably for the last block or two before you get to your destination
EBC - HKS EVC, Blitz IBC or Greddy Profec B.
Why delete the cat? Just get a high flowing cat. If it is the HKS turbo kit, leave the cat as is.
Definitely aim to keep some kind of catalytic converter in the vehicle to at least keep it street legal. There's no point in having a nice performance car if it gets taken off the road for failing emissions tests in random inspections. It's way more hassle than its worth.
cheers :no:
Cheers, then shakes head no? *confused*
anyway- what injectors are you using? Did you get a real ECU solution?
Royal Purple is fine, its in my car atm, but as iamhe said - there are better oils again. Buy filters from nissan
As has been said- no need for turbo timer, your expert friend should know that. turbo is oil and water cooled and as long as you dont flog it and turn it off right away will be fine.
Use a simple manual boost controller, unless you like spending 4-600 on something fancy. It'll do the job, but you'll just lose 1.5psi in the top range. nothing bad.
Kit comes with a high flow HKS cat unless you didn't get it. Suggest you use it.
if u get the utec hen it comes with optional boost controller and u cna program 5 different maps and change with press of a button..
As for oil, go on g35 driver and search, for FI most use Mobil 1 or Shell Rotella Syn T
RP is expensive and doesnt like our engines...
If you have a mongoose alarm most have turbo timer func built in you can program. If not then dont worry about it, just drive it slow before you get home and let it cool down..
cheers for the help guys,i know i dont need the t/t but was trying to be cautious.
undecided about ecu got a couple of weeks to sort it out before install
surprised to hear that about royal purple my mates swear by it but then again they drive commodores lol
also im missing one of the centre caps from my LMGT4 rims they are two piece with the outer one a threaded plastic cap you can see them in the picture. Any idea where i can buy one or is it easier just to buy a new set in a different style? cheers
exhaust manifolds and front end off, new manifolds and turbo on!
the bloody heat shields were the biggest pain took an hour to get each one off!!!
only a bees dick of room for the turbo didnt think it would fit for a mo!
intercooler next :yes:
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
