  • Replies 86
Posted Images
I decided that it was important to properly test these to confirm quality for our members....
so off to europe I went just to check these were ok
I can confirm they are water proof
snow resistant
and keep you warm at at least -8.. so should be ok for melb winters
bet your kicking yourself for not ordering..
snow resistant
ha, awesome
  • 1 month later...
