Hi boys and girls just wanting some opinions on a body kit. Im getting a sunroof installed and decided that I would do a whole makeover at once, respray, bodykit and sunroof. I was looking at the do luck front bar, final conexion rear and side only because there are only 2 bodykits for the 4 door that actually look good, or the 400r front bar which one is better.
Edited by scotty boi
https://www.sau.com.au/forums/topic/407373-which-body-kit/
Im looking at getting some rays wheels soon just got to get the cash together and not sure what looks the best on R33 s anyone that has rays wheels or somthing similar please share photos would love to see them, cheers.
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6495647
dude stop being lazy, and just google it.
a billion people have rays rims on R33's
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6497641
"Photography" subforum > "R33" thread & Bob's ur uncle
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6497856
That makes me want a 33 4 door
That is bad right?
Not when they look like that!
Who ever owns that one has done a damn good job. Good stance, beautiful paint, and the kit is well put together. In saying that though, I haven't spoken fondly of too many four doors at all.
https://www.sau.com.au/forums/topic/407373-which-body-kit/#findComment-6504057
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
