Hey guys i know its not a skyline but you guys will know all because after all its an rb25.
Well the car drowned(fully under water, dnt ask haha) had a snorkel but obviously not sealed. Motor had water in it and now it wont turn over fully, i put a wrench on the harmonic balancer nut and it will turn over to a point then i have to go bak the other way till it gets to the same point again. Also when i go to turn it goes soft hard soft hard, i thought with the spark plugs out it would be all the same resistance? Have i bent the rods?
Im half way in removing the head, nearly at the stage of undoing the head bolts. So i will know more tomorow.
Its an S1 RB25 BTW, i might have to do a rb25/30.
For those reading thanks for your time as i know its not a skyline :)
Zac
Edited by zac320
https://www.sau.com.au/forums/topic/407442-rb25-powered-gq-head-removal/
  • Replies 49
Guys i know somethings buggered hence im taking the head off, just thought it might be a valve bent stopping it from fully turning over, if its the rods, ill get the head worked a bit and just throw a RB30 A6 bottom end in it. Looks like its a pretty straight forward conversion
really? Sorry mate someone has told me that even with a bent rod it should still turn over, so i just assumed valve because i know these arnt free flowing.
Rb30 here i come haha. Can i use the rb25 ecu with the 30 bottom end?
Thanks for the replies
Hey guys got the head off today, what should I do to the head while it's off? Like I might aswell do it up abit. It looks like cyl 3 and 4 have bent rods, so instead of doing the 30 bottom end I'll see if I can source some cheap rods, does anyone have some laying around?
Cheers
try get a running motor. pulling the motor appart will cost you a motza to do it right. you cant put a RB30 straight in as it will need an ecu and tune at a minimum.
2nd hand motor, pop it in, rock on out.
Yeah but the easiest thing to do is just put 2 new conrods in, take sump off and undo 4 bolts and there out, then the head just goes straight on and hook everything back up, then I can build up the rb3O I got
Old 253's and low tech stuff may be that simple but i cant see an RB25 being that simple due the clearances etc........But hey, prove me wrong :D Good luck either way.......... 2ND hand motor seems the simplest!
Okays guys well because my patrol had a RD28TD in it the rb25 swapped straight over, well im picking up a rb30 N/A engine for pretty cheap, i dunno whether to just re ring it and new big end bearings because that can be done pretty cheaply. Or just throw it in and boost it and buy a bottom end thats been done already when one comes up for sale? Also what should i get done to the head? Its had new coil packs but ive heard there no good and i should use spitfire ones? Also i know ill need a new ecu so whats the best bang for bang so i can look out? At the moment it just has a 25 ECU but it would be waterlogged.
Thanks again.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
