Shaved head, piercings, covered in tatts, both arms, back, chest lol
I've shaved the head right back a couple of times, got 4 piercings on my ear/face, one tatt on shoulderblade..but you win :P
Lifts kettlebells in Ugg boots. lol
Kicker right there ladies and gentlemen.
6'6" and 160kg. He's 21yo and had his first ever session on June 8 2010
He failed a 40kg x 5 bench press that day, only got 4. He weighed 105kg
He now squats 300kg, bench presses 180kg and deadlifts 300kg
Those figures are just obscene.
The best motivator for improvement is competition
The highest level of competition is Worlds
If you cant make big improvements going to Worlds, may as well hang it up now
Tolga, Max is now 89kg in the morning, he wants to lift in the 100kg class next year
Jacks improvement has come about because of his 55kg weight gain, plus not missing workouts
Yeah Jack is obviously a bit of a unique case, his genetics are obviously near on PERFECT for powerlifting. Normal people don't get that huge and that strong. He's gifted, that's for sure.
I'd love to get into competition, but since I ultimately lift weights for appearance reasons, I can't make the time for competition regimes :(
Spiros, Emad and Max all hit PB's today, 17 days till they lift at Worlds
Spiros squatted 230kg, Emad squatted 232.5kg and Max squatted 250kg
Nina and Amanda both hit bench PB's, theyre off to worlds as well
Amanda benched 67.5kg and Nina benched 77.5kg, thats 2.5kg above her own WR
Had 5 new people join the gym this week, strength is on the rise
Waiting for Nick to do a Saturday morning session, best session of the week
Me? not sure I can hang with those boys! what's the go on Saturdays? I could really do with some coaching...
That squat from Max was soooo smooth, serious power
How much does Emad weigh? bloody strong for a lean bloke!
So in an attempt to get stronger out of the hole I setup the pins at the very bottom squat position and did dead start squats... I attempted the PPP program in this fashion but it was not happening... had to drop 10-20kg off each lift! ... bloody hell its hard with no bounce
Then bench, going well, trying to practice the pause
Then straight leg deadlifts standing on blocks... stretch those hammies! I can barely touch my toes:/
Dips / face pulls
good session
already feeling better/stronger... even pinched some protein powder off my old man
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
