I'll have to ring abc and talk to them.
I have found a few different bars on this website:
http://www.gymandfitness.com.au/6-foot-olympic-barbell-commercial.html
There's a 2m womens cross fit bar on there as well which has the length taken from the sleeves, but it's pretty pricey.
The one I linked to says its got 1230mm worth of shaft between the inner part of the collar, but I have asked them how much room for plates there is on each sleeve. Don't wanna sacrifice to much weight plate room if I can get away with it.
So I may have to step up to a 2m bar instead of 6ft.
Thanks for your help Markos.
Yeh i get that part, but I don't need 1310mm between the inner edge of the collars. Just bigger than 1150mm so it'll work with my rack.
So the ideal bar would be 6ft long, have like 1200mm between collars, thinish collars and then be able to maximize sleeve length.
I should just knock down the wall so I can go a full size bar, but that won't go over well with the owners of the place haha!
I think you will struggle to get a decent amount of space on the 6ft bar. When I bought my rack I had a 6ft bar, it would fit in the rack but there was only about 20mm from the bit where the plates sit up against to the J-hooks - not very good when trying to rack quickly.
Edited by Dani Boi
Ok, ordered the bar.
The other thing I need to sort out is the rubber flooring for where I will be doing my lifting. I will be doing deadlifts, power cleans, front squats and maybe some snatches etc once I get my technique down.
I was thinking about just getting 1 or 2 of those 15mm commercial gym floor rubber tiles that are 1m x 1m. Then cut them in half and have two 50cm x 1m long strips about 1.1m apart.
Do you guys think the 15mm rubber tile over a concrete slab will be thick enough for dropping bumper plates onto from shoulder height? Or should I put one ontop of the other and have it 30mm thick on each side? I would like to keep the bumper plates and my bar in good condition.
Then I'll just get some ply wood that is 30mm thick and put it down on the concrete slab in between the tiles and have my own portable platform of sorts.
I would go all out and build a proper lifting platform, but I need something that can be broken down easily and moved/stored without takin up a lot of space.
Edited by Mitcho_7
just for those interested.
A group of people from Aus went to the GPC WORLDS competition in Slovakia.
There have been over 10 medal winners with a bunch of them being Gold.
Main one so far, the Owner of PTC Brisbane Scott Wasson has set 2 World records (1 for deadlift and 1 for total) and 4 Aus records (squat, bench, deadlift and total) and won Gold.
Scotts WR total (724.5kg - 257.5 squat, 165 bench, 302 deadlift) is an all time biggest total 90/93 raw in any fed in oz
Some of the bigger fellas lifting today.
If anyone is interested in watching the live feed you can here...
http://www.powerlifter.cz/live/
It should be starting about 4pm AEST.
I'm sure Markos will have more info and vids/pics etc when he returns
Edited by TTT
awesome effort, what a beast! must be the beard... I'm hoping mine gives me a few extra kilos
was watching the girls on that feed yesterday... in my limited experience the judging seemed very lenient, anyone who knows their stuff care to comment?
was inspired so last night we did: squats, Bulgarian split squats, good mornings, bench press, DB overhead press, cable chest press/flyes... completed in just over an hour... I'm tired today lol
Yeah Nick I thought the same about the judging from what I saw.
the press calls were REALLY quick too.
The judging is ALOT more strict at GPC Aus.
Couple of Brisbane fellas lifting today
Zach Turner - 140+ kilo, 19 year old, squats over 300kg, benches 180ish, dead around 250
Ricky Goodyear - around 105kg - 37 years old, he is opening on 300/190/290
yeah I really don't know enough to have an opinion either way, but it does get a bit confusing when your new to the sport
Those numbers are funny looking at on screen, your like yeah sounds impressive... but to actually load that shit up on a barbell and get underneath it... fck me
thing is, because they use proper thin metal 25kg plates, it doesn't look like much either
Compared to say bumber plates or the chunky shitty rubber coated plates that most gyms have (and I have at home).
Until you see the bar bend... lol
especially in the deadlifts, they use a texas deadlift bar which has some flexibility to it.
when loaded up with the likes of 300kg, there is a fair bit of bend in it.
The texas bar has a *lot* of flexability. I can feel the difference around 100kg off the floor.
By the time you get to 200kg the sides leave the ground significantly later than the middle, and it gets worse as you add more weight :)
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
