had a very successful States... I went 9 for 9, setting a PB on every lift
squat 210kg
bench 132.5kg
deadlift 240kg
unfortunately the 90kg division was very strong so I came 4th... if I had of lifted in any other division I would've got a medal
was an amazing job Markos, how you and the crew managed to run a meet with so many lifters and spectators out of that little gym was super impressive
bring on Nationals:)
Cheers! I had a good day... I like comps, I find I can get a few extra kilos just due to the atmosphere
I started doing PPP 3 times a week after my first novice comp which was last year in September I think... that was at my old gym with the odd weekend session at PTC... since mid Jan this year I've been training 4-5 times a week, mainly at PTC, doing a mixture of PPP and whatever Max tells me to do
booked in to have a coaching session with Trent from PTC Sydney next Saturday. Will be interested to see if I have been dead lifting or squating incorrectly.
also any other tips that he can give.
I think it will be more beneficial for my brother who has only just started going to the gym.
Nick, some are destined to stay weak and small, they'll never understand you eat for size and lift for strength, as you pointed out, Martin and Gregg are both Elite, different builds. Same training, one eats more. It doesnt seem difficult to understand. Anyway, please dont post that crap in here, its clearly a PL thread, PL is a sport.
