The reality is though, I'm not a competing lifter so the pause isn't a big thing. As long as I'm not bouncing the bar off my chest, just lowering and pressing in a controlled manner that's all that I care about.
I agree however pausing reps may assist with shoulder health... from what I've read
have you had a go at the Bamboo bar Markos has there?
had a quick muck around with it but that's about it... very odd to use... I imagine its similar to doing push ups on rings / TRX straps... building the stabilisers in your shoulders by pressing an instable object
I'm still trying to press a stable object correctly lol
nope from what I understand, Bench press is a test of shoulder health. You do need stronger shoulders/ scapular support to do it though, it's definately harder than not pausing.
Just curious as to whether any of you do rack pulls to improve your deadlifts?
Asking because my deadlifts are up at around 145kg, whereas my rack pulls are around 180-185kg.
It would seem the lower section of the lift is what I need to work on (my lock out is strong)
Any good ways to go about this?
I would have thought everyone would be stronger on rack pulls than deads, given it's only half the movement.
Deadlifts on a deficit, power cleans, should help with lower back.
Rows are upper back, but they do strengthen core and lower back at the same time. Seated row with lower back movement might be good.
Yeah I know it's always going to be the weaker part, this is why I want to work on it.
Once I improve that drive off the floor I'll be pulling some respectable numbers.
My gym doesn't have kettlebells so I'll give deficit deads a shot.
In my limited experience and understanding the floor part is sometimes mucked up by a combination of things. I am trying to remember it was a long time ago.
Most often I reckon getting the bar off the ground issues are 'the setup' and things like the approach based on your flexibillity and body mechanics.
When I started doing some deads again for that challenge, I had to start stretching my ankles to ensure I had enough dorsiflexion. I had bugger all straight away,to what is really needed. I still need to work on it if I ever want to play with something heavy.
Try these if you haven't already.
* Take all slack out of the bar hold before going for it. Stretch into tension by griping the bar and pulling up to point of tension a couple of times before the real lift. Crush the crap out of the bar. If there is any slack at all in the grip, then energy is lost as it's taken up (and the hips are probably going to leave the bar behind)
* Hips trying to come up too early as you try to 'heave' the bar off the ground.
* You need to 'push' yourself away from the floor and drive through the feet. (This is probably one of the most effective tips for getting the bar off the ground).
* Drive hips through the bar.
* Keep the tension in the back/lats not just the abbs.
I reckon posting a vid and someone like Markos can give you some pointers.
One thing I slacken on from time to time...but it makes a big difference...is starting with that bar pressed right up against your shins. The closer to your centre of gravity, the easier it's going to be to get that sucker off the floor. This means dragging the bar up your legs (grazing them on knurling haha) as you lean back and drive hard with the heels.
Every now and then I find the bar a couple of inches in front and I have to slap myself for it.
Mark ripptoe explains it well in starting strength.
Scapula should be directly over top of the bar, arms vertical, bar in the middle of your foot (which will usually find it resting against your shin/ankle). Pretty much what I recall his deadlift guide explaining.
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
