The reality is though, I'm not a competing lifter so the pause isn't a big thing. As long as I'm not bouncing the bar off my chest, just lowering and pressing in a controlled manner that's all that I care about.
I agree however pausing reps may assist with shoulder health... from what I've read
have you had a go at the Bamboo bar Markos has there?
had a quick muck around with it but that's about it... very odd to use... I imagine its similar to doing push ups on rings / TRX straps... building the stabilisers in your shoulders by pressing an instable object
I'm still trying to press a stable object correctly lol
nope from what I understand, Bench press is a test of shoulder health. You do need stronger shoulders/ scapular support to do it though, it's definately harder than not pausing.
Just curious as to whether any of you do rack pulls to improve your deadlifts?
Asking because my deadlifts are up at around 145kg, whereas my rack pulls are around 180-185kg.
It would seem the lower section of the lift is what I need to work on (my lock out is strong)
Any good ways to go about this?
I would have thought everyone would be stronger on rack pulls than deads, given it's only half the movement.
Deadlifts on a deficit, power cleans, should help with lower back.
Rows are upper back, but they do strengthen core and lower back at the same time. Seated row with lower back movement might be good.
Yeah I know it's always going to be the weaker part, this is why I want to work on it.
Once I improve that drive off the floor I'll be pulling some respectable numbers.
My gym doesn't have kettlebells so I'll give deficit deads a shot.
In my limited experience and understanding the floor part is sometimes mucked up by a combination of things. I am trying to remember it was a long time ago.
Most often I reckon getting the bar off the ground issues are 'the setup' and things like the approach based on your flexibillity and body mechanics.
When I started doing some deads again for that challenge, I had to start stretching my ankles to ensure I had enough dorsiflexion. I had bugger all straight away,to what is really needed. I still need to work on it if I ever want to play with something heavy.
Try these if you haven't already.
* Take all slack out of the bar hold before going for it. Stretch into tension by griping the bar and pulling up to point of tension a couple of times before the real lift. Crush the crap out of the bar. If there is any slack at all in the grip, then energy is lost as it's taken up (and the hips are probably going to leave the bar behind)
* Hips trying to come up too early as you try to 'heave' the bar off the ground.
* You need to 'push' yourself away from the floor and drive through the feet. (This is probably one of the most effective tips for getting the bar off the ground).
* Drive hips through the bar.
* Keep the tension in the back/lats not just the abbs.
I reckon posting a vid and someone like Markos can give you some pointers.
One thing I slacken on from time to time...but it makes a big difference...is starting with that bar pressed right up against your shins. The closer to your centre of gravity, the easier it's going to be to get that sucker off the floor. This means dragging the bar up your legs (grazing them on knurling haha) as you lean back and drive hard with the heels.
Every now and then I find the bar a couple of inches in front and I have to slap myself for it.
Mark ripptoe explains it well in starting strength.
Scapula should be directly over top of the bar, arms vertical, bar in the middle of your foot (which will usually find it resting against your shin/ankle). Pretty much what I recall his deadlift guide explaining.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
