what was the point of that vid?
some chick lifts 235 lbs (105kg) then drops it.
a 26 year old 44.8kg girl deadlifted 135kg on the weekend.
and lowered it too.
didn't scream.
Its crossfit. Very angry individuals.
LOL TTT... you get me every time
my Mrs accidentally tried to deadlift 95kg last night... apparently she mis-loaded the bar... broke the ground with 3 attempts but couldn't lock it out... then got really angry thinking it was only 75kg... when I heard the story I had a good chuckle
silly woman
Edited by NickR33
This is Max playing around in a bench shirt for the first time. For those that dont know, powerlifting has two divisions, raw, which is what 99.9% of regular gyn goers do, and equipped.
With equipped, the lifter wears "suits" or "shirts" to allow them to lift more weight. Its actually a different sport to raw, you actually miss lifts because the weight is too light, like in this video. Max can bench 160kg at the moment, but 140kg wasnt heavy enough to touch his chest.
I am slowly going to introduce equipped lifting on here. I dont expect you guys to adopt it, but I'll try and get you guys to understand it.
An equipped lifter is not compared to a raw lifter.
Australias best powerlifter is Wayne Howlett. He has the All time biggest totals in raw and equipped.
Raw its 935kg and equipped its 1010kg
Anyway, here is the vid
and lowered it too.
didn't scream.
I thought the lowering phase wasn't encouraged on heavy lifts. Heard that from strong-man Elliot Hulse
Strong-man is not powerlifting.
Deadlifting a barbell is not a strong-man event..
A deadlift is lifting a stationary weight off the floor and lowering it back down.
not lifting it off the floor then releasing it.
Deadlift in powerlifting requires you to lower it in a controlled manner. this doesn't mean slowly, but it does mean controlled and not dropped.
dropping it from the top means the lift is not counted.
Dropping it from the top at any gym will mean you're kicked out.
anyway, congrats to the super strong girl who deadlifted 105kg then threw it and screamed which is a good effort because she doesn't spend 6 days training for strength which was stated on the video in invisible html code obviously.
Wonder what she is lifting now it's 4.5yrs later in 2013
Isnt it an NA auto 4 cylinder?
The merc? Or cefiro?
The merc is a turbo 4 cylinder.
Ive put in a turbo back exhaust and remapped it recently. Not sure how much more im getying out of it atm.
/shrug
Specs
Puahing Number of cylinders 4
Engine size 1.8 L
Fuel PULP
Engine aspiration Turbo charged
Driving wheels Rear
Claimed max power (kW) 135 kW @ 5250 rpm
Claimed max torque (Nm) 270 Nm @ 1800 rpm
Transmission 7-speed automatic
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
