PTC Eltham is opening this weekend.
PTC Canberra will be open shortly, equipment has been ordered/purchased, searching for a suitable location
Another PTC around Cairns next year
The boys at PTC Perth are looking at a opening a few more, surrounding Perth
We may have another north of Brisbane in 2014
Update on other events.
We had a Novice Comp in October, there were 44 competitors and between 200-300 spectators during the day
With the lifting, the girls this week
Heidi benched 90kg@66kg
Rebecca benched 70kg@60kg
Sussy benched 80kg@58kg
Rebecca squatted 140kg@60kg
Sussy squatted 135kg@58kg
Vicki benched 60kg x 3 @ 60kg
Vicki squatted 110kg x 2 @ 60kg
Arrione squatted 115kg x 5 @ 70kg, no wraps no belt
Arrione clean and pressed 60kg x 3
Arrione deadlifted off 7.5cm blocks 170kg
Ebony deadlifted 105kg @ 16yo
Ebony squatted 80kg @ 16yo
Katie squatted 90kg x 5 no belt no wraps
With the guys, we now have 3 that have deadlifted 300kg+, Jack 310kg, Zoran 305kg, Dan 300kg. Today Dan, Zoran and Martin are going for PB's, Martin should also pull 300kg making it 4 at PTC
Next in line is Roger who pulled 290kg last week and Spiros pulled 280kg, Albert also pulled 280kg at 17yo
Dan benched 190kg@125kg
Stelian benched 172.5kg@105kg
Max benched 170kg@90kg
Albert benched 170kg@100kg and 17yo
Martin benched 162.5kg@95kg
Martin squatted 260kg
Albert squatted 280kg x 2
Allen squatted 240kg@80kg
MENS ALL TIME RAW WORLD RECORDS
56kg class - 289/177/287.5 - 607.5kg
60kg class - 255/180/285 - 667kg
67.5kg class - 255/192/315 - 716.5kg
75kg class - 305/220/325 - 777.5kg
82.5kg class - 322/252/359 - 816.5kg
90kg class - 344/256/390 - 878kg
100kg class - 387/264/408.5 - 950kg
110kg class - 400/273.5/402.5 - 1000kg
125kg class - 400/295/400 - 1044.5kg
140kg class - 450/302/426 - 1072.5
SHW class - 453.5/322/460 - 1084.5kg
WOMENS ALL TIME RAW WORLD RECORDS
44kg class - 102/80/145 - 287kg
48kg class - 145/93.5/172 - 394kg
52kg class - 154/105/185 - 417kg
56kg class - 167.5/112.5/192 - 417kg
60kg class - 174.5/136/206 - 474kg
67.5kg class - 213/137.5/240 - 535kg
75kg class - 217.5/142.5/242 - 572.5kg
82.5kg class - 235/150/247 - 609kg
90kg class - 190/163/238 - 555.5kg
SHW class - 295/195/263 - 748.5kg
Haven't been on this forum in ages, very busy with work and any spare time I'm at the gym training
Training all lifts again, back seems to be fully recovered. Chiro was impressed with the time frame for my rehab. He figured I might be out a lot longer.
Training for the ProRaw ProAm at the moment, although just coming off a nasty flu that kicked my ass so not where I'd like to be. Just want to get another comp under my belt as I haven't competed since states. My goal was 600+ kg at 90kg this year, I'll go over 600 but my bodyweight is hovering around 92-93kg and I won't be cutting.
So after a really good start to the year it's been all over the place ever since. Hoping 2014 will be more consistent.
The new gym is awesome and some huge improvements from many lifters. Pretty amazing to watch really.
What kind of numbers are you looking at for each lift to go over 600?
I should squat around 230kg, bench hasn't moved since Nats (actually gone backwards if anything) so I'll be happy to press 140kg again and I should deadlift 250kg+... pulled an easy 240kg today
amazing my deadlift feels better than my other lifts and I really haven't been training it as frequently or as heavy as my other lifts... weird
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
