Hi guys I'm pretty sure I need to rebuild it but I thought it worth asking the question. Last week I was about to race at Sydney dragway but I thought maybe I should do a compression test as I hadn't done one since fitting turbos. Cyl 1 to 5 were 150psi and #6 was 100psi wet or dry, the engine had been run that day but wasn't at operating temp. It doesn't use oil and still goes as good as it did at the skyline drag day where it ran 12.1 at 118mph. So I'm wondering if there is another test? I disconnected the cas and turned it over to listen for any difference while cranking but it sounded the same on each cylinder. Before I changed turbos I also attended a Wednesday night where the coil packs gave up and that's the only time I can think of anything actually going wrong with the car, but since then it's been dyno tuned and done at least 10 passes, is that possible with one cylinder 50psi down? Or am I just clutching at straws and need to rebuild it ?
Scott
https://www.sau.com.au/forums/topic/407845-rb26-compression-question/
  • 3 months later...
Hi guys just a quick update I decided to do hot compression test to see if there was any improvement and I did #5 and got 145 and #6 and got just over 140 with both I did for above 10 secs on starter I didn't bother checking the others as previously on the cold test they were even, so what does this mean? I'm looking at installing my -5s and 1000cc injectors and e85 but I don't want to waste time if the engine needs to come out, any opinions are appreciated. Scott
Hot dry test 145 and 140psi? Seems like a tired engine....boost it up should be right ! Haha
if he had some aftermarket cams, 140psi might be perfectly normal, and now there close in comparison compared to the original 50psi difference in number 6, and doing 12 second quarters it must be pretty healthy..
If your worried its the cam timing, mark where the cams are ATM. Than move them both back to 0 test the comp and see if there's a diffrence.
Than just set the cams back to the marks you made before you drive the car again.
Sorry I meant cam gear adjustment it has hks gears and its never been changed since it was tuned more than a year ago so I have no reason to think that has anything to do with it, it has 290kw at the rears but was limited due to afms still being stock but he said it made the power very easily,
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
