just replying to cam r u running an aftermarket bov and an air flow meter or a map sensor i know that some nissans run a system that when engine rpm is below 2000rpm the fuel pump circuit switches voltage from 12v back to 9vdue to fuel pumps being too noisey toyota soarers run this system as well have u set base idle and iac learnt where base idle is car looks great
  • Replies 242
maybe some help with nissans stalling are most of the cars have standard ecu and aftermarket bovs because when bovs fitted the bov stays open @ idle because of the manifold vaccum which in turn bypasses the airflowmeter and run exceessivly lean so when u up the fuel preassure may temp fix the problem to check to see if problem fixed put a 1 way chek valve on the vaccum side of bov e.g xf falcons have a 1 way valve on the carby version its green and black this stops the bov openning @ idle or when pulling up to lights and still when on boost holds the bov shut and when gears changed only lets of excess preassure and not too much boost which in return slows turbo lag. just trying to help a few nissan owners
cheers.
I just recently purchased a 1995 Series II R33 and it appears to have a stalling problem aswell.
The spedo first started to just drop out down to 0 and would come back if i gave it a bit of a tap. it still does it now. I had a 3point alarm system installed, and not long after getting it back the car began to stall. it doesnt just stall at a low rpm but usually does around 400rpm. I could be driving and the power will just cut out. not just when i am approaching a stop point.
Im not sure if it could be something that happened when they installed the alarm system or if it could be something relating to the spedo and the wiring in the dash with its gauges, just looking at some of the other posts it makes me think it could be something else.
any suggestions would be greatly appreciated.
I would like to share my own stalling experience.
I have a r32 gtst auto (full 3inch system is the only mod), my car use to stall when coming to a stop, going around corners, and at times when cruising at around 3 grand bunny hop. Occasionally it would cut out even when i wasn't coming to a stop.
The solution to my problem was really quite simple. Clean the airflow meter.
So i took off the airflow meter and gave the sensor a good clean with electrical contact cleaner (available at Tandy dick smith etc). Now, no more stalling issues.
I can tell you the most important thing all the nissan people out there, the connector/s to airflow meter is the most crital connection in the entire engine managment and it is the cause of most problems in nissans of any breed. After all the MAF is used in practically all fuel based mathematical calculations within the ecu. If you have any problems with you car running shit go and check the connetor to the MAF. I guaranty it will fix most problems
hey guys. i have a r32 GTR and i started to stall the other night =( the revs kept dropping and it wanted to stall it was ok for abit i took it for a spin around the block and it stalled on me i took it back home and left it running for awhile and it kept stalling and stalling and stalling. so i turned it back on and hit the throttle afew times to about 4000rpm then let go i got alot of black smoke coming and it back fired like a mother =(. think this could be just a fuel pump prob? black smoke? back fire? anyway could someone give me more detail instructions as to how to ground this earth fire on the fuel pump? like a picture diagram ^_^ thanx
Sounds like it is running extremely rich, for what reason I dont know though.
  • 3 weeks later...
I think everyone should check out there CRANK ANGLE SENSOR - Coil Packs - & for series one rb25det's , they should check out the signals coming out of the Ignitor pack, that sits above coil pack #6
like anyone is going to listen to you in this community mate u screw people
f#ck off
mmm my 33 does it, infact did it twice today.... only mods i got are pod and bleed valve...... scared the shit out of me coz i was coming to an intersection and i slowed to take the corner, car stalled but i didnt realise for some f**ked up reason lol coz i still had lots of momentum, but i lost power steering while i was half way through the corner and allmost hit a car coming the other way :s
threw it back into second and took foot off the clutch and it roll started and was all good again, but it scared the $hit out of me
-Ruffels
Might be a TPS error if the MAF sensor has been checked and believed to be working. Calibrate the TPS so that it is 0% with the throttle shut. Take note you will probly need a Nissan Consult to perform this proceedure. This should kick in the IAC valve when the throttle is shut, ie when coming to a stop. Let us know how you go.
mine was starting to do that quite a bit.. going from higher speeds to low speed turns, revs would dip, then jump up. Sometimes they wouldn't jump up enoigh and it would stall. Changed AFM over the weekend.. problem fixed. The other one was dirty I'd imagine.
  • 3 weeks later...
it is weird how all nissan owners come across this somehow
got the problem in my 180 at the moment - car is in shop and let mech know so hoping he can find it
the usual checklist to go over is as follows:
* check all your vacuum lines for leaks
* check bov isnt leaking
* check AFM
* check o2 sensor
* check TPS
* check IACV
* check fuel pressure (which is wat this re-grounding the fuel pump earth whoo haa is...)
* check ecu pin outs and connections
* check not running excessively lean or rich
that seems to be all the usual suspects and if you check all of them thoroughly you SHOULD fine the problem
  • 1 month later...
could somebody please tell me which wire needs to be cut and re earthed. i cut the black wire that comes from the pump and re earthed it. it didnt do much, but my fuel gauge reads empty. so im guessing thats not the right wire. how can i find out witch wire is meant for grounding??
I have an R32. I believe that the ground is the top-right wire when looking at the pump-side clip. It is a white wire which is thicker than the others. I think the others are as in this diagram
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
