Hey all been my dream for awhile to do a 26 powerd rx7, I know all the pro and cons, I have the engine ect ready just want to know ha some one done this in Australia????? Or tried? I'm ginna give it a hot go but abit of guidance would be so grateful so please any help would be awesome!!!
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/
  • Replies 63
I measured up a series 8 a couple of weeks ago for an rb30/26 conversion.
After we spent a couple of hours going over what was required the owner decided to settle for a 20b instead.
The list of parts to be custom made was massive and very labour intensive.
Are you capable of doing alot yourself?
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6507232
Really? Damn it, I was gonna get someone else to do it I want it to be perfect look amazing got a couple of people interested in wanting to do it but they havnt done it before, what was some of the custom parts? Im a mechanical engineering fitter so I work 6 days a week so not much time ether, I've got 7k budget after buying the gearbox,rb26,custom rear whell drive sump ect. Hope it's not for nothing :(
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6507475
Why don't you do a LS1 mate?
Cheaper and you can buy an over the counter kit from the US for a full installation. I know someone who did it and it was flawless and you can DIY it basically as it's a full installation kit. By the time you sell all your bits + the 7k you already have - you'd EASILY have thick wad of spare change.
Lighter motor, will make 260-280rwkw with a big cam and the stock ECU can be tuned easily... Can't argue the viability in the value factor and it's a fairly rare conversion still :thumbsup:
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6507523
That's true to ^^ and would sound awesome!! Haha mite have to look at that to, I was gonna go RB cause Ive had them most of my life haha, what's your thoughts or 2jz? I can buy over the counter kit for them to but they don't look as good RB :(
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6508223
If your going to do a big 6 cyl conversion why not look at measuring the car up for a barra xr6 turbo.
Exhaust is already on the correct side, engine bay is long enough.
Sumps come in front or rear pan (BA/BF or FG) any aftermarket ecu can run one, parts are cheap and the engines are reliable/Grunty.
The major issue you have is engine height, the rx7 lacks depth which was the major concern with the rb26. 2jz and barra will be worse which is why the ls1-ls7 is actually a good idea.
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6509490
  On 30/08/2012 at 2:33 AM, DVS JEZ said:
Put the 26 in a old mustang. Dom and his boys have done it. Thing drifts awesome.
Dom is crazy! he lives his life a quarter mile at a time. Nothing else matters: not the mortgage, not the store, not his team and all their bullshit. For those ten seconds or less, his free.
https://www.sau.com.au/forums/topic/408045-rb26-fd-rx7/#findComment-6510084
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
