Woo Hoo Dump Pipe Finially Arrived
Originally posted by Black33
inasnt, I ordered the exact same dump from arrow diffs as well. its good cos he sent it cod and mine should arrive tomorrow
:D
u bastards! now he has a whole stack of lasercut flanges so it wont take em long to make up the new 1's!!
  • Replies 152
nah, I don't think so cos when I spoke to him, he had just made this "batch" up (his word - like he just took some cookies out of the oven) from the laser cut flanges he had just received.
anyway, he said that he made up a bunch (maybe 10) and he must have sent you one of those, and then when I spoke to him yesterday - he only had about 2 left - so I got one of the last ones. :D
Have you measured the diameter of the pipes at the turbo flange side? wanted to know how big the wastegate pipe is.
the guy u r talking to i am assuming is Rama! he talks abit of shit!
Mine was the original order with 1 other that he had to do before he got the whole bunch of other orders. thats y he sent me mine quickest, 4 weeks is still 2 bloody long.
i will measure the wastegate hole when i get home, they could have made that pipe a bit bigger!
thanks man, yeah thats what i thought from the pics - but he said it was 1 1/4 or 1 1/2 inch and that what the ones at jms are, so I guess it's ok
when u planning on putting your in?
mines going in on friday, with new plugs and s-afc tune!
mines going in on saturday along with a front pipe being made up and having my cat flanges flared out to 3" at a place in south yarra!
(SAFC to come later for me)
I just spoke to rama and he said that wastegate pipe is around 35 mm (between 1 1/4 and 1 1/2 inch). he made a good point by saying that the hole for the wastegate is samller then this so this size is more then enough - anyway if the wastegate pipe didn't flow enough, all it would mean is a tiny bit more boost under high revs :D
yep, was gonna do it on sat at ice but thats the only time I can get the dump etc fitted so will have to wait till next saturday!
what would you estimate I'll be on after the dump front etc? (have bleed set at 10psi, airinx pod, cold air partition and super drager)
what will I then get to with a tuned safc later??
its hard to say with different cars and different dynos!
come down to calder this sunday and see what u can run in the 1/4 mile, thats the best indication of power!
might be going cos a friend is taking his vl turbo - but I don't know if I'm gonna take my car down??
what are the people there like, never been!!
its good i went last friday but didnt run! i just wanna go to race my friends vr 5.0, thers sum real quick ie 9sec cars but it's just fun 2 see what your car can do!
update!
gerald just called me, the new dump pipe aint matching the location of my 3 inch front pipe, so its going to exhaust shop now to get the front pipe cut and rotated so it fits properly!
This means no dyno tune today, and since grand final is tmorow the dyno shop is closed, so i gotta wait till monday to get the s-afc tuned!!! FARKKKKKKKKKKKKKKKKKKKK:mad:
Originally posted by ex-static
damn.. so will you be comming to the meet tonight?
depends if i get my car back tnite! might be tmorow morning!
he had to drive it to exhaust shop with no exhaust, straight off the dump pipe, that would have sounded sweet!!:)
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
