Woo Hoo Dump Pipe Finially Arrived
Originally posted by Black33
inasnt, I ordered the exact same dump from arrow diffs as well. its good cos he sent it cod and mine should arrive tomorrow
:D
u bastards! now he has a whole stack of lasercut flanges so it wont take em long to make up the new 1's!!
  • Replies 152
nah, I don't think so cos when I spoke to him, he had just made this "batch" up (his word - like he just took some cookies out of the oven) from the laser cut flanges he had just received.
anyway, he said that he made up a bunch (maybe 10) and he must have sent you one of those, and then when I spoke to him yesterday - he only had about 2 left - so I got one of the last ones. :D
Have you measured the diameter of the pipes at the turbo flange side? wanted to know how big the wastegate pipe is.
the guy u r talking to i am assuming is Rama! he talks abit of shit!
Mine was the original order with 1 other that he had to do before he got the whole bunch of other orders. thats y he sent me mine quickest, 4 weeks is still 2 bloody long.
i will measure the wastegate hole when i get home, they could have made that pipe a bit bigger!
thanks man, yeah thats what i thought from the pics - but he said it was 1 1/4 or 1 1/2 inch and that what the ones at jms are, so I guess it's ok
when u planning on putting your in?
mines going in on friday, with new plugs and s-afc tune!
mines going in on saturday along with a front pipe being made up and having my cat flanges flared out to 3" at a place in south yarra!
(SAFC to come later for me)
I just spoke to rama and he said that wastegate pipe is around 35 mm (between 1 1/4 and 1 1/2 inch). he made a good point by saying that the hole for the wastegate is samller then this so this size is more then enough - anyway if the wastegate pipe didn't flow enough, all it would mean is a tiny bit more boost under high revs :D
yep, was gonna do it on sat at ice but thats the only time I can get the dump etc fitted so will have to wait till next saturday!
what would you estimate I'll be on after the dump front etc? (have bleed set at 10psi, airinx pod, cold air partition and super drager)
what will I then get to with a tuned safc later??
its hard to say with different cars and different dynos!
come down to calder this sunday and see what u can run in the 1/4 mile, thats the best indication of power!
might be going cos a friend is taking his vl turbo - but I don't know if I'm gonna take my car down??
what are the people there like, never been!!
its good i went last friday but didnt run! i just wanna go to race my friends vr 5.0, thers sum real quick ie 9sec cars but it's just fun 2 see what your car can do!
update!
gerald just called me, the new dump pipe aint matching the location of my 3 inch front pipe, so its going to exhaust shop now to get the front pipe cut and rotated so it fits properly!
This means no dyno tune today, and since grand final is tmorow the dyno shop is closed, so i gotta wait till monday to get the s-afc tuned!!! FARKKKKKKKKKKKKKKKKKKKK:mad:
Originally posted by ex-static
damn.. so will you be comming to the meet tonight?
depends if i get my car back tnite! might be tmorow morning!
he had to drive it to exhaust shop with no exhaust, straight off the dump pipe, that would have sounded sweet!!:)
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
