The former is a halogen bulb intended to look like an HID.
The latter is an HID bulb.My knowledge of the V35 is hazy at best so I'm not sure if the OEM headlights are HID but if they are, then you'll need to have retained the HID ballast and retaining clip from the compliance conversion.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515148
I generally stick to the terms 'HID' and 'halogen'. Xenon is a bit ambigious as HIDs are filled with Xenon gas, but you can get halogens with traces of Xenon gas also.
So the term Xenon doesn't really define the type of lamp.
As Sean said, factory low beam are HID. If the car was complied proplery, they would have been removed and had halogens fitted. However there are plenty of V35s getting around still with their factory HIDs in tact, either re-fitted after compliance, or complied by a workshop that didn't know they need to be removed.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515279
I'm not really sure what it has at the moment as I'm not the first owner.. The left is working but the right has blown. Best bet would probably be to take the right one out and find out what it is hey? It has been checked for defects and what not when i brought it from Melbourne and they said nothing about them so maybe they are halogens?
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515777
I should hate stated xenon halogen aha apologies.
Go up to your headlight cover, and look at the bottom you will see little engravings it should say D2R. If you aren't sure, remove your front bumper and look for a ballast (a box with wires connected to it leading to the headlights) and read what is written on that. If you have a ballast, you have HID's and i believe if there is no ballast you have Xenon Halogens. It's a little confusing. My right headlight has blown too, i am planning on buying aftermarket lights but i need to take my bumper off and look for the ballast to see what will work with my car.
Goodluck!
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515784
Uneducated response here, but don't HIDs take a half second or so to come on, while halogen would be instant on?
My low beams have a delay, and for that reason alone I believe they are HIDs. The high beams, which also emit a different colour light, come on instantly and I believe they are halogen.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515940
HIDs do have a smal delay, but the most noticeable effect is the don't come on at full brightness when cold, they take about 15 seconds or so to reach full brightness, and they tend to be a bit 'blueish' as they warm up.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6515972
Just checked - my low beams are a blueish colour & highs are yellow. Lows have a very slight delay turning on from cold, and also take a few seconds to get to full brightness - as per sonicii but not 15 seconds, maybe 3-4. Highs come on instantly.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6516200
Out of curiosity, since I haven't converted my lights back to their original HIDs, I have noticed that my high beams don't seem to have as much reach as they probably should. I keep the AFS switched off to avoid the AFS alarm from the lamps not being able to swing at all since the conversion and to obviously avoid any mechanical damage as a result. Do our headlamp assemblies start in the lowered position perhaps and that's why my high beams aren't really pointing high up like they should?
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6516319
Hey guys just a few quick questions - I have removed my headlights and I have halogens, but there are little grey units with yellowish stickers bolted onto the bottom of the headlights with wires coming out of them (cut wires), is this the factory hid unit? If so how would I go about setting it up? Is it difficult? Are there any diy's?
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6516587
So you have HID low beams and the top lights are Halogen :)
Does it look a little something like this? If the wires are cut and not connected to anything, someone has been lazy and left the HID ballast in there. It might not be in use, but if you get the appropriate bulbs to suit HID bulbs and the wiring you need you can try hook it up but do a bit of research first. G35driver.com is a great forum with loads of info on pretty much anything and everything to do with these cars, give it a shot.
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6516735
Yup looks like the one in the pic.
So all I need is the wiring and globes?
Would these fit?
http://www.ebay.com....=item27c0ff9d43
Thanks
Correct, and obviosly you have to make sure the other end of the ballast is connected to something lol.
You have to be careful with D2R and D2S they use different bulbs.
Edited by Seano350GT
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6516996
are you sure they are different? All the ones I've found on ebay say d2r d2s and even d2c!!
http://www.ebay.com.au/itm/Nissan-350Z-Murano-Subaru-WRX-STI-D2S-D2R-Factory-Xenon-HID-Replacement-Ballast-/170720897409?pt=AU_Car_Parts_Accessories&hash=item27bfc22981
Even that says d2r d2s ^
I'm so confuse :(
https://www.sau.com.au/forums/topic/408386-xenon-lights/#findComment-6517001
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
