So the car is now for sale.
It is an Aus delivered 1998 Nissan 200sx S14a
kms: 205,000
All the items listed below were fitted/rebuilt/reconditioned at 150,000km. so everything is still fairly new.
real reason is I want to now jump into an evo. FOUR DOORS TIME!
here is a very brief list of what has been done, you will need to call me to find out some more.
Pictures, can be found all over the internet, ie facebook, websites.
or here at carsales
http://www.carsales....00~1&sort=Price
ENGINE
Built to handle over 350kw by JRE(james race engines) in Flemington
Eagle H-beam rods
Venolia Forged Pistons 8.5:1
Custom "Wade" stage 2 cams(unsure of spec)
Ported and Flowed head
ARP L19 Head Studs
Cometic 1mm head gasket
Tomei Cam gears
ARC Sump extension
18 Row Oil cooler - braided lines etc
Drift Catch Can
All being held by Megan racing Engine Mounts.
+Plus more
INTAKE TO EXHAUST
BLITZ High flow panel filter
Custom 3" Alloy Suction pipe
FMIC bar and plate-modified piping that doesn't go through the battery plate(LEGAL)
3" SS turbo back exhaust
Catco Cat
Varex 3" rear muffler
TURBO
TOMEI M8270 including
Tomei actuator
450hp+
ELECS FUEL
Power FC & Hand controller
Z32 AFM
Bosch 040
Nismo 555cc side feeds
XS adjustable FPR at 35psi Base
DRIVELINE
Exedy Triple HD Brass Button Clutch
Gearbox replaced my Status Gearboxes(have receipt)
R34 GT-T 4.11 Helical LSD + 5 bolt Shaft
Slotted and dimpled RDA Front Rotor
Slotted RDA Rear Rotor
QFM A1RM pads all round
HEL ADR approved Brake lines
HANDLING
Varrstoen 2.2.1 Nitto Invo Tyres
18" 9.5 +12 245/40/18
18" 10.5 +22 275/35/18
Tein Superstreet coilovers
front whiteline castor bushes
Whiteline Adj front and Rear Sway Bars
Whiteline castor arms rear(poly ure bushes)
Whiteline Camber arms(poly ure bushes)
D-project arms, and Subframe Brace
Including poly ure bushes everywhere
INTERIOR
AEM wideband/ electronic boost gauge
Oil Press gauge
customer stereo surround
ARK Design Sparco Seats with Bride Rails
S15 jap steering wheel
Nismo Knob
Clarion USB HU
EXTERIOR
Full Vertex Body Kit
Crystal indicators
Carbon Fibre Origin Boot lip
sticker bombed fuel cap(can be removed)
Lamborghini Pearl Orange duco(Arancia Calafornia Mica 954165)-done by Pati Panels
Flared guards-about 35mm to fit big tyres
Body is perfect no accident history and no rust!
Tuned by Cihan @ eTuner.com.au to 270RWKW at 19psi on 100 octane.
Too much time & money has been put into this car to make it as perfect as it is. buyer will love it.
Photographers love it too. Here are some websites and photo shoots.
Most recent; LEIGH KELLY
http://www.facebook....leighkellyphoto
http://www.facebook....09774779&type=3\
NPho
http://www.facebook..../#!/NPho.com.au
http://www.facebook....69308791&type=3
NishiMachi; wimmin included lol
http://www.facebook....achiPhotography
http://www.facebook....50405518&type=3
Serviced every 5000km including plugs - or earlier if I feel like it.
This car very rarely see's the road now days, and is just sitting in the garage. furthest it does at a time is about 15km a day. This is a very well known car and i'm sure anyone can tell you good things
A lot of the fabrication has been completed by Scotty at Scotty's Customs
Im looking for a figure of $18,000 which is cheap considering the amount of effort put into this car. BUT; I am open to reasonable offers.
PLEASE DONT WASTE MY TIME(WASTELAND INTENDED) AND NO TYRE KICKER/DREAMERS/TEST PILOTS
GENUINE INTEREST ONLY TO CALL OR SMS 0403 090 011
time for change - interested in an EVO
Spread the word - will be appreciated.
Funnily enough I have an Evo 8 that would be of interest to you, but it ain't for sale, unless the price is right!!! however I do have I do have an M35 Axis for sale....
Very nice package your S14 is....
lol i hate you a little. and thanks lol
Would not buy these...just sayin
who are you implying that for, if the 200 then GTFO my thread
CAR COMES WITH A ROADWORTHY!
Also to add comes with a choice of gtx3071r(Turbosmart kompact 40mm ex gate) or the tomei m8270 as listed in OP
Very limited time for the above turbo choice
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
