Great day out.
Massive thanks to Jack for letting me take the keys to his GTR for the day... Certainly very different driving experience to how my GTR was setup before i sold it. I have new appreciation for the Racepace transfer case modifications :D
Didn't get any footage of the ducks/geese on Mega Mini Wang on my run where i had to go off road mid-run to avoid... By god that was a very close call to utter disaster.
Fun times, great day - thanks to all that make the days happen.
https://www.sau.com.au/forums/topic/408844-sept-deca-wrap-up/
  • Replies 175
^lol @ the 86. Go Az, go!
Bring on teh pics!!
don;t know about you but I'm watching the pics on a number of face book feeds getting messier and messier.
This was an awesome day! Thanks guys for putting this on, it truly was an experience I won't forget!
Quick question, When will we be able to see all of the videos that were filmed with that tripod on the skidpan?
I thought they were for some weirdo's "personal" collection
thanks to the event organisers and volunteers. great weekend.
am keen for times and slow-motion videos :)
if someone wants a hand entering times into the spreadsheet, im happy to help out. got Monday off to recover
Ash... Thanks for not smashing my GTR... One of the best DECAs I have been to. Courses were much better then any previous Deca I have done. Well done to organizers.
I was being as kind as i could mate :thumbsup:
Certainly more challenging to drive yours, was farken good fun.
It was good fun to be back at a DECA day, but because I was not driving it really got me wanting to get back out there in my car.
Just checked my Drift Calendar and for once DECA and the drift day are 1 week apart, so I can do both :D
First time, had an absolute blast, as has been said thanks to the organisers for making it all happen and for making it an open event,
the atmosphere was great, i was driving the gold with black roof 180sx which is a good fun car.
Cheers,
Andy
Hey Martin, Nice video. Did you have a steer this time?
Good to see Aaron out having a go! He loops the 86 better than a WRX that's for sure...
nah trying to behave myself a little atm, so no decas.
Painfully didn't even got out in shepp as we had to be in melb early morning.
add to this I'm missing december one.
SO I have come to a conclusion.
we best have some flying fishes for first one next year as I'm putting in my entry now ;)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
