Hi guys, just bought a set of 275/35R19 tyres and had them fitted to my rims 19x10 + 20. I am getting some fairly significant rub on full lock and at any time the car bounces while driving (oh yeah aso have adjustable coilovers). Would you guys say it's because of the 35 profile on the tyres or the +20 offset of the rims? Do you think if I went to a lower profile tyre (30) it would alleviate this problem?
What tyre sizes (and rim size with offset) are you guys running on your GTRs and do you get any rub? Cheers
ps. I am aware there is a similar thread already running, however I thought this would be easier for the 34 GTR owners rather than sifting through pages of forums, with this thread also specifically being about tyre rubbing :)
Edited by Iron Mike
  • Replies 41
Posted Images
i haven't got a gtr, the 30 profile will only help in the same way as raising the car slightly, assuming the guards are rolled already, you could try a stretched tyre, raising it up, more camber or more offset depending on where it's rubbing on full lock
This ^
Raise the car until it doesn't scrub or roll guards
Just for ur interest I've got 18x10 + 18 with ku36 265/35 all around and these tyres are chunky with no stretch
Raised the car afew millimeters and no rubbing
This is on 32 gtr, ur 34 has bigger guards
As above it will be too low rather than offset related.
I'm running 19*9.5 ET2 (265/30 tyres) & I'm now getting a lot of rubbing on the fronts since lowering my car more
Really need a roll
Dunno if you guys have seen it, but i used the miata tyre calculater to check the tyre sizes. I had stretched 245/45-18 on my last rims, which were 18x9.5 + 12, and with the new tyres, the diameter/radius of the whole wheel is almost identical, which leads me to believe that it probably isn't the profile of the new tyres causing the rubbing and may just be the wider tyres or the higher offset with the current rims (+20 as opposed to +12 on the 18")...
Yep 19x10 with a 275/35 - what do you expect?
You can fit 18x10.5 with a 285/30, still have a little rubbing if it's too low - this is all the same stuff we went over in your other threads anyway.
this. You asked if it would scrub, we said yes, you didnt listen
What tyre/offset combos in 19" do you think would minimise this problem or is it inevitable? I remember guys with GTRs running 19s with no rub, just cant remember what tyres and offset :/
I think you're thinking of the wrong member. I don't remember asking this question anywhere!
First of all a 275/35 is a dumb size, there is no other way to put it. It's so wrong it's not funny...
Anyway you need a 275/30 - then you get an extra ~1cm to play with. It's MUCH closer to stock diameter which will stop your speedo being "too" far out. With a 35 profile tyre it'd be so far out it'd be ridiculous.
Either way you cannot have both (10" rim and a 275/35) if you want it remotely close to lowered.
You want lower you have to go with a 275/30.
OR
Going back to a 265/30 on a 9.5 and it's over 1cm and almost the same diameter as factory - which is what most people do
Only reason I didn't go for the 30 profile was that many people were saying it's really bad for the rim if you hit a pot hole, but I dont know seriously how much difference going up to a 35 profile would make anyway. Secondly the diameter of the wheels im running now are almost identical (only 2 mm larger) to the diameter I had when I was on 245 18s with a 45 profile...
:huh:
Regardless of 30/35 - you hit a pothole - shit is gonna get farked up!
You'll end up rubbing on the inner guard would be my guess.
As i said a 18x10.5 & 285/30 combo will rub with a moderately lowered 34GTR on the inner guards. Going 19s isn't going to make it any less likely even going a 275 which is only marginally smaller
Whether or not it effects rubbing but rolling circumference of the tyre is too big for your car. Buy the correct size tyres FFS.
Hey Anthony, can you please send me pictures of your wheels and where it rubs. I'm looking at getting the same wheels but with +12 offset and dont know if its only going to compound my problem. What made you go for the 35 profile also?
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
