Ive been asked about turbo selection by mates who want to turbo their diesels.
2 have land cruisers with 4.2l diesels and another is rebuilding a 10.2l cat diesel to put in an old cruiser as an unlicensed farm car.
Does anything we use on our cars even come close to suiting a diesel? Both cruisers would rarely see 4000rpm but with the capacity difference they would only require a bit more air?
The guy with 10.2l cat engine would prefer twin setup. I'm unsure of the characteristic differences required between the 2 fuels and it got me curious.
Hoping someone has experience or could point me in the right direction.
Cheers
https://www.sau.com.au/forums/topic/409074-diesel-turbos/
And people put the HX35 onto 2.6ltr motors and then wonder why they are buckets of sh*t :D
it's not much chop on the 5.9 Cummins either, but that is the stock turbo so that's what went back on
though I think it's more the breathing setup on the truck more than the turbo, and the factory waste gate is 2 bar
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6527996
Yuh, petrol turbos and diesel turbos have different sizing of compressor relative to exhaust housing. Tends to make them not great matches when swapped.
Smaller compressor to turbine?
Would imagine 1.06 rear as they would be under load for longer and response is less of an issue?
Might see if Stao makes/modifies anything for the 4.2's
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528052
what about a 2.5 diesel turbo on a 2009 nissan navara? what could be done to give it a bit more go without massive expense like computers etc my bro just bought one.. :yes:
Edited by SliverS2
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528053
Mate put a 3076 anti sugre with a .82 rear on his GU Patrol TD42, highmount manifold and external gate. Thing is super responsive and makes about 180rwhp, which for a diesel is a lot.
I beleive Kando are starting to make some TD05 combo's aimed at Diesels, United Fuel injection in Perth are using some now.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528067
Single cab in that goldy colour and lift kit?
One passes my place regularly and I can hear it spooling from miles away
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528076
Block wastegate hose :whistling:
lol.. i dont think he wants 30psi.. the later models have a variable vane turbo, maybe one of those would be a good upgrade.. answered my own question..
i wonder if one of the housings could be slapped on a skyline for extra response..maybe discopotato would know
so do diesel engines work well with gt30's?
Edited by SliverS2
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528100
try a 3" exhaust and a performance chip, 20-30% increase depending on quality of components
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528250
I was looking at some Gensets i worked around. Detroit Diesel 8.7L Inline 6. 200HP @ 1500RPM (Genset so locked to 1500RPM).
Wasn't able to see the ID tags on the turbo because of the turbo beanie that was wrapped around it.
But no wastegate, looked to be something similar sized to that of a GT30 with a huge exhaust housing - go figure its a diesel. Non water cooled core. I did see the compressor wheel on one when the engine was getting a service and it had quite a small compressor wheel.
After going through all the engine parameters on the Genset control unit, i cam accross Boost pressure. Boost pressure was holding at a constant 0.1 - 0.2 Bar. Which is bugger all. I believe in this instance these engines are turbocharged purely to get more efficiency out of them.
Another story, a friend of mine is currently working out which turbo to replace his current one on his 5L (3 Litre) Hilux engine. Currently has a TD04-13G. According to MTQ and Adelaide turbo services keeping that Turbo is ideal for that enigne.
Bit of a story there but maybe some of it was useful :whistling:
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528384
I've worked on 6L- 60L gensets and they all ran 15-25psi. Sounds like yours wasn't loaded up
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528401
Diesel exhaust temps are somewhat lower than high strung petrols.....so the variable vane mechanisms usually shit themselves fairly quickly when misapplied (ie used on petrol). Only Porsche and a couple of others have gone to the effort of engineering variable vane petrol engine stuff that can handle it.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528409
That was with 70% Load. I thought the exact same thing when i first looked at it. Then read the screen three times, and yes very low boost pressure. Its exactly the same when the Gen sets are unloaded as well.
https://www.sau.com.au/forums/topic/409074-diesel-turbos/#findComment-6528414
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
