  • Replies 45
Have you had a chance to measure temps yet Hayden?
Considering doing this and trying to work out if the size you've picked is big enough, and if it's not where to fit something bigger :unsure:
I'm halfway through fitting up the temp gauge, so I should have some info soon (finding time is the problem unfortunately)
One temperature variation I have noticed is the outside ambient temperature display in the dash...
After the car's been driven & parked for a short time, the outside temperature shows high 30's or low 40's thanks to the temp sensor sitting directly above the oil cooler core. :O
I'll get around to relocating it one day.
My oil sits around 87-90 degrees, and the water 76-80 on the freeway with the Nismo thermostat. That is with a 30 row 12an oil cooler. I guess the Greddy oil thermostat is set a little high. I wonder if the water-oil cooler is affecting it's operation...
I have still seen 118 degree oil temps at PI, even though the oil cooler has a 14 inch thermo running flat out. You can never have enough cooling at the track as I found out.
Great story. Was quite entertained!
Hows it go; Greedy pays twice!
AND
You get what you pay for!
Made in YumCha not so good, not so love you long time....lol...
Well done on sorting it all out in the end.
Years ago I was told that cooling the oil is more efficient than a radiator at keeping an engine from cooking. I never believed it till I put one on a V8 with chronic overheating issues. The core was approx 200 x 300mm (sold by a truck spare parts place to "cool a Mack" - I lol'd at him). So put it in & it instantly fixed my overheating problem. In fact I reckon I could've run without coolant, except I wanted the heater to work. Had to block the airflow (to the cooler) in winter so the engine had a chance to get to operating temp.
The one Hayden chose looks plenty big enough to me.
Edit: to clarify, mine didn't have a thermostat. That would've been a better idea, but meh, cardboard worked ok.
Edited by Commsman
Cheers Hayden. Be good to see how it goes.
Where did you mount it mate? Got a photo?
Thats what I'm interested in. But you havent got one in your Stag yet do you?
No I don't, but I also don't have cooling issues, yet. If there was such a thing as a finned sump, it would probably provide all the extra cooling a modified road car would need. (Not talking track days here.)
Is there room somewhere out of the front airstream to mount a cooler? That would radiate a fair amount of heat by itself, or a small fan (or 2) could help (thinking computer case sized). I don't think there's room in front of the radiator in my car either, so one day could have to look for alternatives.
Anyone else noticing a slight handling change everytime they add more weight ahead of the front axles?
Edited by Commsman
Nah thats cool Craig. I'll pull the bumper off when I get back and see what's what.
Tells me we only need a little one, which should be easier to mount. Say a 10-13 row. Just Jap have some really good pricing on the ones that Hayden used here, and there are some decent adaptors on ebay. Should be able to get something half decent for ~$150 plus hoses.
Look for a sandwich plate that allows you to angle the lines to/from it at 45deg like the Greddy ones.
Try to buy one similar to this: http://bit.ly/TJfXJw
If the adapter is one that only has the inlet/outlet coming out at 90deg to the filter, chances are you'll foul the hoses on something like the aircon lines...
You can get the grex thermo plate with a the two sensor bolts for about $140 delivered from the US. Scott has the details. Or do what I did and wait for a good deal to pop up. I think there is a hks cooler with sandwich plate for a pm35(same thing) on IM ATM......works out to be about $450 delivered.
I'll check out the US deal Craig, thanks. The one Hayden linked to looks like it'll be fine too.
GCG have them locally, but a bit pricier: http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1132&category_id=201&option=com_virtuemart&Itemid=101
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
