  • Replies 72
Posted Images
So quite simple, who has the coolest numberplate, removing the (no doubt unstoppable) discussion on if having a personalised numberplate makes you a knob.
My plates read BCNR33. Got them with the car.
Saw BNR34T on an urban 4WD of some kind (Audi if I recall) the other night. lol'd.
Saw the plates FOMOCO on a Toyota Corolla today.
FOMOCO is the acronym commonly used for the Ford Motor Company, specifically their racing parts and muscle cars.
Edited by Amaru
Saw "BNR-33T" (nsw plate) on some kind of softroader. (pathfinder maybe???)
^^^I put this in the Plates that make you LOL thread.^^^
Coincidence ???
Flamin' Mongrels takin' all the good plates. NO FAIR !!!
Sinista's Plate is pretty damn fine as far as cool plates go.
Coincidence ???
hahaha as my post above, saw the same car :P
Was it 34T or 33T ?
Definately was NSW plates, but I can't be sure of model of car as I was still asleep on the way to work.
(dumbf**k o'clock)
I think it was redish ish in colour?? :blink: maybe...
regardless it was definately a WTF? moment. LOL.
Was it 34T or 33T ?
(dumbf**k o'clock)
It might be someone who used to own one and wants to keep the plates (for a future car maybe?) so has just chucked them on another car instead of paying to store them.
Wow, so BNR34T and BNR33T are both out there, being used on softroaders and not for their true purpose.
Makes baby Jesus cry. (he builds hotrods after all).
Tis a shame that these people do this and not pass em on but I guess a plate is just a plate.
A numberplate, by any other name, would smell as rich.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
