So I am a proud owner of a 1990 Nissan R32 GTS4T 4 door RB20DET Auto just under 115,000kms and it has had the 100,000km service completed only couple of months ago (love manual but I needed a 4 door and this was the only one available that was also Turbo, the auto in this config is better than the manual imo as no loss of boost going through gears but sucks at take off but I can get it to drift, though to continue to link up drifts really need to power on and swing the car side to side to keep it loose and shift between 1st and second and ride that boost, really driving the car hard to drift a 4wd and would benefit from an increase in PSI).
It has been looked over by the RWC mechanic and Pedders, somethings were found by both but Pedders found a few more. They really are the suspension specialists.
So I need the following parts to complete RWC and just to bring the car to a good mechanically sound level. The links are just what I have found on ebay and am open to advise and other products.
Front upper control arms with new bushes fitted was considering a pair of these http://cgi.ebay.com....#ht_3816wt_1163 I have been quoted $150 for a reconditioned pair of stock ones.
These are the dimensions, are they suitable for the GTS4T? I thought $160 for pair shipping included wasn't bad. Don't want to pull off stock ones to check dimensions if I don't have too as I still need the car to get around in.
Inner and Outer CV boots are worn and the grease is all gone and the joints have been damaged so are clicking I have been advise to change the complete CV shaft left and right. So both left and right front CV shafts, joints and boots required. Are these what I need?
Rear tie rod end bushes (They look like a knuckle setup, they are the ones out at the wheel you can see it from looking under and behind the wheels) I will take some pictures and post.
All discs need machining due to being worn, rusty & glazed but I have been told these are lipped and cannot be machined so looking to upgrade to a slotted vented pair thinking rears can stay stock style but need new discs.
Front http://www.ebay.com....9#ht_632wt_1163 Rear http://www.ebay.com....9#ht_500wt_1180 not sure if slotted really needed for rears.
Left hand front shock very firm near seized both front shockers advised to be changed. What is a good value for money pair?
Left hand top shock mount requires replacing due to shock failure it has been taking the brunt of the absorption, should I change left and right or just the left damaged one is ok? If just left I am looking for stock one if both I saw these http://www.ebay.com....a#ht_500wt_1180
Front D Bushes worn need replacement (sway bar mount bushes) is this a set that will fix this? http://www.ebay.com....4#ht_1679wt_960
Light play in steering rack it PASSED for Pedders and RWC mechanic but they said should be looked at in the next 6 months, I think it is fine but wondering what a reco one will cost and is a 2WD rack different to a 4WD rack?
Radiator hoses are hard and crunchy and need to be replaced. Found this http://www.ebay.com....#ht_1401wt_1163 are they correct ones.
I need a Left dash heater air vent
The CENTER GEAR CONSOLE SURROUND is cracked,pitted,melted by cigarette burn and chipped so was looking at this, seems pricey though, but the ad mentions more durable than stock one.
http://www.ebay.com....#ht_1514wt_1163
Hoses behind radiator, in front of motor (oil cooler pipes) need new clamps. Hoses are slightly perished but not the cause of leaking it is the clamps that are at fault for leaking but they recommend changing hoses and clamps at same time and advised only need less than 1.5mtr of hosing to do, what is the dimension of the pipe that is required? I can pick up a length from super cheap unless there is a highly recommended alternative product.
Rear under side has a little surface rust and they recommend treating it with fish oil anyone concur?
Found this, is it needed? http://www.ebay.com....#ht_2406wt_1163
So supply of parts if any are for sale would be awesome but peoples advice both on parts choice, compatibility and pricing would be appreciated.
Edited by Aljo
Sorry just realised from a couple of PM's I received I did not mention I live in Buderim Queensland Sunshine Coast and use the courier site http://www.interparcel.com.au/ to obtain the goods which requires suburb of pickup and packaged dimensions and weight so I can tally up full costs to do a deal. Thx for the current pm's.
Click pictures for links to sale sites on Ebay.
Regarding Front shocks and front drive shafts (cv shafts,joints & boots complete).
1st how do these shocks compare to stock ones? $430 with shipping buyout don't need rears but eventually I would so thinking on value per pair.
GAZ Adjustable shock absorbers to suit NISSAN SKYLINE R32 1989 ONWARDS
or SKYLINE R32 - FRONT ULTIMA STRUTS (SHOCKS) $220 pair shipped
487091720_o.jpg?nc=9
For the front drive shafts I found these forgot to link ebay page for them $165 with postage how do they measure up? Do they look ok?
Edited by Aljo
Find another mechanic.
Also play in steering wheel could be steering column spacer bush.
Funny you should say that you are the 3rd person to say that to me. I am going to search for a Jap Import mechanic the mechanic I use his partner is friends with my wife and he has a different take on what passes for road worthy than other mechanics do or the laws in QLD differ from NSW and VIC which is where the other two people who said the same thing as you are from. Also he favors american muscle cars so I am not sure what his angle is. I am going to fix everything else then decide on where the steering rack stands on needing to be replaced. But good to know column spacer bush. So just out of interest what influenced your comment on the mechanic.
Question about cv joint shaft recondition rebuild.
I was told that once the boots have been ripped for a while and grease is all gone and cv's start clicking, rebuilding them to a reconditioned level is a waste of time, what is peoples opinion of that?
So I have found these shocks on EBAY has anyone had any experience with them?
Nissan Skyline R34 KYB Coilovers - Drift JDM Dish S13 S14 S15 R32 R33 R34 180
It looks like an awesome price but not sure on the spring rates and if it would be ok for daily driving
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
