  • Replies 40
UPDATED LIST!!! PRICE DROP!!!
various trims $name your price
centre console brackets $1
power steering reservoir minus cap $5
centre dome light without cover $5
driver door loom $5
washer bottle loom $5
number plate lights $5
front windscreen washers $5
ignition/headlight reminder beeper $5
stock rear audio amplifier $5
sun visor clips $5
wiper amp $5
Mirror triangle cover thing - $10
drum brakes (in bits and pieces) $10 for both
Pod filter $10
front reading lights $10
HICAS computer bits $10
blower fan $10
bonnet lining $10
brake booster $10
brake pedal $10
centre console hand brake leather $10
centre console front trim $10
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
hicas steering rack $10
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side kick panel $10
roof lining $10
steering column (minus the bottom part of the shaft) $10
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
alternator - had battery juice spilt on it from the accident, might still work $10
boot rubber seal $10
catalytic convertor sensor $10
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
ignition loom $10
driver side door solonoid $10
flywheel cover $10
open door sensors $10
passenger fog light (lens is ok, plastic a little cracked) $10
various metal sheild bits $10 the lot
wiper switch $20
rear wiper motor $20
cluster surround $20
interior wiring (includes wiring that goes into the boot) $30
rear seat belts $20
hazard/stereo switch $20
outer door handles $20 each
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
castor rod arms $20 each
hicas module $30
side mirrors $40 each (driver's side has a small crack on the side)
front control arms x 2 $40
rear calipers x 2 $70
Passenger side mirror gone!
centre console/handbrake surround gone!
2 x kick panels gone!
passenger side a pillar trim gone!
seat belt bolt covers gone!
passenger side rear seat hand rest panel gone!
  • 1 month later...
The remaining parts have been listed as a $1 NO RESERVE eBay auction - http://cgi.ebay.com....em=261147664144
I want this stuff gone! Happy bidding!!!
Only 3 hours left until the auction closes (see link above) and that's all the parts gone from my wreck! Get your bids in or miss out!
LAST CHANCE!!!!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
