I thought these turbos were very smiliar, based on the same trim. However, I was going to pull the trigger on GT2530 and then my friend came to me and said that the -5 is actually rated at 360hp while the gt2530 is only 320hp.
can you please shed some light on these 2 ratings?
https://www.sau.com.au/forums/topic/409688-hks-gt2530-vs-garrett-gt2860-5/
Same rear housing, turbine wheel and comp cover. There is 1.1 mm difference in the comp wheel, the 2530 being the larger of the two.
See if Elrodeo666 gets in here and tells you what HKS said themselves about these two.
Don't have time to search the part numbers but if you are comparing a "GT2530" to a GT2860RS in RB26 housings then yes cartridge wise the only difference is minor variations in the compressor wheels . On paper the RS is a 62 trim 60.1mm OD wheel where the 2530s is a 63 trim 60.1mm wheel .
Its not just all in the inducer size and exducer tip heights will make a difference .
Also I think HKS does their own turbine housings but not sure if there is any significant difference internally , both are 0.64 AR .
If you want the original chico roll and can find used ones to freshen all you need is the HKS supplied turbine housings compressors and compressor housings .
You could also inquire about buying the HKS spec cartridges from Garrett because sometimes they can supply HKS spec cartridges . You would have to check but from memory the cartridge number is 446179-21 .
A .
What size engine is it?
What are you doing with the car?
2.6.
I'm doing spirited drive and drag mostly. I pretty much maxed my gt-ss so I decided it was time to go a step higher.. I will ask my tuner to play with timing so hopefully we can turn a little the powerband to the left and I might add a carbon shaft to try to get ake it as responsive as my actual setup but with the topend of these.
I notice one thing people never do with GTSS turbos is experiment with the next size up compressoe housings . I don't remember exactly the dimensions of the GT2859R compressors but they are not exactly tiny in the GT25/GT28 world . I think Garrett intended GTSSs to use a housing very similar if not the same as std turbos and it was intended to help make these turbos wind up early - or earlier than your typical GT2860R turbo .
GTSSs use the same RB26 specific (compact type) 0.64 AR turbine housing as most Garrett 26 type bolt on turbos and the main hot side difference is the 62 rather than 76 trim size of their NS111 turbines .
Once you step up from an RB26 specific GTSS to a GT2860R type turbo you get the larger compressor housing and the larger trim turbine .
Something to research is the four cylinder version of the GTSS because it uses the big or 76 trim NS111 turbine but its compressor is a 60.1mm 60T rather than the 62/63 trims of the GT2860RS/ "GT2530" compressor wheels .
A .
I spoke to a local turbo shop and they offered to convert my gt2860-r to the spec of the RS or even the gtx2863r.
I understand what your means and your advice are great but I think I rather work around the -5 than the gt-ss. aybe I'm wrong but I think this way will be easier than the other way around.. not to say that the gt-ss have a good resale value.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
