Hi Skliner's,
Every R33 owner I have spoken to about their car always seem to have a deep feeling of 'affection' for their car,....more so, I believe, than many other owners of 'other' types of cars. Being in the lucky position of owning a beautiful white 95 GTST, I Know first hand why we feel this way.
On the other side of this, is there anyone who feels that the R33 has any design faults, things you don't like, stuff you'd get changed in a heart-beat, things that 'pi5s you off'. Not just mechanicals (if any), but interior, exterior, quality of systems, ride quality (before and after you modded it) etc.
I would like any comments on what YOU FEEL about YOUR R33.
I don't know too much about the fantastic R32, because I don't own one..but pls feel free to comment aswell,.....if you like!!
- The stock tyre size was a joke.
- ABS should've been standard
- The boot is too small for such a long car
- Active LSD standard or a cheaper option wouldve been nice. Would see more around.
That being said there is so much to like about the R33. The car is well engineered from front to back from the huge stock calipers to the still-sexy-ten-years-later styling.
:headbang:
er no.. maybe only costs too much :D and mods cost too much :)
as it comes out of the factory it could do with a few things (bigger turbo, bigger wheels, bigger intercooler, better suspension, better exhaust) but afterall, it is just a run of the mill factory production car. Nothing really comes out that great from the factory.
Interior is a bit bland i guess to start with.. bit of paint and rice fixes that
When I get in my car, first thing I do is put both windows down. To put the driver side window down, all you need to do is press the automatic-down button. For the passenger side window, you need to hold the button for ten or so seconds. Both windows should be the same.
Corner extremities of the car are hard to see - so makes parking a much slower and care oriented activity - with still the rick of a touch as you can't see where the car ends.
All very good points, passenger window switch bugs me too!!
And I'm sure we'll all agree that even after 10 plus years, she's still a hornbag looker of a car !!!
WHAT ELSE ?..........KEEP GOING!!!!!!!!!!!!!!!!
Yeah, the passenger window switch is a bastard - although im sure you could find another drivers side switch and put it in the passengers window for the same effect!
As for the 32:
- The fuse box is an absolute prick to change fuses, and the ones in the engine bay are a bitch to pull out.
- The tyres could have been a bit wider :):)
- Corner extremities of the car are hard to see - so makes parking a much slower and care oriented activity - with still the rick of a touch as you can't see where the car ends. - I just lowered my car so low that i can see every other cars bonnet over my boot hahaha :-) Problem solvered!
- The boot is too small even for my gold clubs
- Stock tyre size, well everyone changes that so irrelevant
- I got LSD so happy about that
- Series 2 interior and ext is alot better IMHO...but could do with a decent head unit, but hey everyone replaces that too...
- I have no real bothers other than the occassional bit of rust the creeps in places that is shouldn't...they are a well manufactured car and will test the times far better, with more power and with greater style than ANY Australian built car especially in those days...
the autolock thingo shits my passengers where you go above 20km/hr - but that is their problem not mine.. therefore i care little :(
chef_32.. what you don't use the passenger override thingo.. that is fun sometimes :D
I think the trim they have used on the seats is butt ugly. And the cup holder sucks, it's only capable of holding one of those crazy little japanese cans.
I'll second that - have tried only once to keep one of those thermal coffee holders (the silver variety) in there - almost resulted in a caffeine drink for the seats and the carpet
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
