Of course it's the stock ECU. That's what the Uprev Osiris cable is made for. I didn't want to go through the process of wiring in another MoTeC like I did in my previous project. Modern cars in particular are so tightly integrated with all their other components that one does not tread lightly in the aftermarket ECU domain unless they want to lose all the creature comforts and some of the OEM performance benefits, such as the all-wheel steering and whatnot. This is where it's best to leave the stock ECU and remap it instead. That's the purpose of the Osiris.
Sorry, got lazy and didn't look up what Uprez Osiris was. Now that I did, did you do the tuning yourself or got a tuner to do it? Then again I wouldn't know what to look for in a tune, have not much experience in it. Might just go with tuners first and then maybe look at Uprev. It looks really interesting though.
Thanks for the info :) Will hit you up if I get more questions if you don't mind :)
I haven't yet done any tuning on it. I only got to drive it for a couple months before I had to fly off to the UK for 5 months work so there's a lot going on now that I'm back on home turf again. The tune will be the last thing I do. I no longer have access to a dyno like I used to so I'll be relying on the services of Tunehouse and hopefully the owner remembers me given I had long hair back in 2002 when we did the MoTeC training seminar. :)
If you know how to tune, it's a logical process but the butt dyno will only be good enough for getting a general tune. After which, a dyno is absolutely necessary for a fine tune and particularly with timing where you need to listen carefully for knocking so that you can dial the timing back a bit. Fuel's easy because you can read the lambda values from an EGO meter. It's spark that's the slightly trickier one.
Someone here has already had theirs tuned by someone in the Central Coast if I remember correctly. It's in their signature with every message they leave so keep an eye out for it. It definitely gives you the most gains for an NA mod and it's about as far as I'd go because I don't see the value in forking out cash on hardware that could be better spent doing a proper forced induction modification instead. Many here will disagree with me but we all still get along despite this difference. :)
Why hack into the ECU wiring loom if you don't have to? The only time I see a piggyback option being feasible/necessary is when you're going for massive upgrades which then require the use of sensors with different electrical characteristics. If all you're changing is the injectors and going mild boost, then an ECU reflash is more than enough.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
