Iv searched everywhere and i can't seem to find threads about people putting poncams into a RB25DE, has anyone installed these before? Im getting the ones that are straight drop in no tune needed. Iv had people who have had decent gains on N/A Sr20s but nothing on RB25DE, if anyone has any insight on this, let me know cheers.
https://www.sau.com.au/forums/topic/410003-tomei-poncams-rb25de/
you could be looking at 10kw for $1000 or so. . . not real good value
This is true, plus the bigger u go the further u move ur torque curve up the rev range, natros need midrange grunt no good gaining 8rwkw up high If your going to lose 10rwkw between 0/4000 rpm.
Only three reasons to do cams in a natro:
1. It's a race car restricted to capacity/induction rules
2. Your intending on spending big money on a natro build (lobe separation I believe are different between na and turbo cams through tomei, well in the 34 anyway)
3. You want a tuff as nails idle (in which case a simple drop in 254 8mm lift won't overly achieve you'll need solid lifters and I big mofo cam (which will result in an off cam lagy pig and more then likely be slower)
Post results
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
