1991 R32 GTR
Car is making 270rwkw on 18 psi on a very safe tune.
GT-C Volk 18x9's all round.
Motor rebuilt approx 10000km ago
Reco block + head were used.
chemical clean all parts, full machine, clearance and blueprint.
ACL comp bearings
JE Forged piston kit
H-beam rods
MLSR steel head gasket
oil restrictors
Genuine nissan gasket set
all new hoses
new genuine thermostat
new water pump
new timing belt
nismo radiator cap
new battery
new heater core
re gassed air con
nismo diff bushes
cradle spacers (pineapples)
600cc injectors
Splitfire Coilpacks
nismo plugs
Garret 28/60 turbos -7
Apexi power fc with hand controller
full kakimoto 3' exhaust
blitz 4 stage boost controler
R33 GTR crank
N1 oil pump
momo stearing wheel+ gear knob.
Tomei 310km dash cluster
new slotted rotors all round (dba)
koyo rad radiator
baffled sump
bosch fuel pump
central locking + alarm and immobilizer
Exedy button clutch (under 1000km)
Good stereo
Car interior has been retrimmed in leather
Bad Points:
Car has surface rust under drivers side rear quarter
Needs rear brake pads
Gearbox is knochty (Comes with r33gtr replacement gearbox)
a small dent on left rear quarter
Car is currently in Tasmanian Rego and that is how it will be sold. Located in Vic
I have over 15,000 in receipts for motor rebuild
16,800 ONO May consider swaps.
Contact me via 0467982414 or PM
Edited by s13en
https://www.sau.com.au/forums/topic/410057-fs-r32-gtr/
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
