Hey guys, I'm looking to instal an aftermarket boost gauge on my R34 GT-T. It's mechanical so i need to connect the hose somewhere on the turbo line. I've searched around the forums and google a fair bit and thought this sorta thing would have been covered already but i really couldn't find much, or anything with pictures, or maybe i just dont understand it.
But yeah, i thought its better to be safe than sorry, so where and what exactly do i cut and put my T piece to connect the hose for the boost gauge?
Thanks heaps
yeah, ive looked around a bit and thats what most of them say. but im not too familiar with where the intake manifold is or even where the vacuum lines are. And instead of cutting something and ruining my engine i was hoping for something a little more detailed.
like a photo would be awesome, or anything a bit more helpful.
Do some reading up on engines and their basic layout - will help you a lot in future.
See the cylindrical shaped thing on the bottom left with a black hose coming out the top of it? That is the blow off valve and the black hose is a vacuum line that runs from it to the intake manifold. You can splice your T piece into this line.
oh okay, thanks for that. I attached an image just to make sure, so the red circle is the tube i should cut to attach the T piece?
I have heard from someone that you can also cut the hose coming from that little black can shaped thing, i circled the tube coming off it. Would i be better off cutting this tube?
So which out of the two would be better to cut.
Another question is, will this cause any problems to occur such as stalling or the car running poorly? It just seems a bit daunting to be cutting a tube going to the intake manifold and attaching a little T piece onto it, thats all :)
Edited by hop1308
  • Like 1
Yes you have circled correctly. As long as it is a vacuum line going to the intake manifold, it doesn't matter which one you cut and splice into. You're cutting into a hose, but the T piece and boost gauge are blocking it up again.
As for issues, there should be none unless you create a leak somewhere. Rationalise that your worst case scenario is having to replace the hose you cut with a new one and what's the worst that could happen?
its not letting me edit my last post, but i looked at the hoses under the hood today and noticed that my T- Piece will fit best on the hose going to the boost sensor as this hose is thinner. I have circled this hose in Blue in the picture, so just making sure, is it okay to cut this hose and put the T piece there to run the boost gauge? the Blue circled one in the post i did above
No, don't T into that hose, as said you won't get vacuum.
On the back drivers side of the intake manifold there will be a vacuum line the same size as that one which goes to your standard boost gauge, T into that.
Basically you can hook your boost gauge up to anything that's plumbed in AFTER the throttle body, except the fuel reg hose, but that's at the front of the engine anyway.
thanks for that, does anyone have a photo of the location i can T into? I'm pretty confused about it at the moment and need to know how much psi my cars at lol.
It'd be the biggest help ever if someone has a photo of the hose, thanks again.
yeah, so if anyone could get a photo of which hose im supposed to put the T piece into, it'd be a great help
I've always T'd into the end of the plenum, where the stock vacuum lines goes into the stock boost sensor for the dash (this is for a R33) I am assuming the R34 is the same.
Look at the black cap on the RHS next to the vacuum line for the brake booster, use that.. or if too hard basket, just snip the BOV vacuum line.. easy.
what's wrong with the stock GT-t gauge? reads up to 1 bar.. perfect for stock turbo
Not really! Its got bugger all notches on it so it would be hard to pick what boost it is...... Useless now with 21psi BUT even before then they were pretty useless!
I will be replacing all 3 gauges sometime soon enough.
yeah i was thinking about using the hose going to the boost sensor, but everyones saying you dont get vacuum off it, only boost. I don't really get the photo of the R33 engine, im not too familiar with the hoses of my R34 yet but didn't want to send it off somewhere just to install a boost gauge.
oh and the stock boost gauge doesn't use a vacuum line im pretty sure its purely electrical.
A photo of a R34 engine bay or the hose i should T into would be awesome and save me having to take it to a mechanic over this =\
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
