up for grabs is a brand new unused z32 nistune ecu with standed base map on it bought straight from toshi recommended by Nistune. need to sell as unexpected expenses came up
rb25 series 2 r33 gearbox no glitterly oil, still looks fresh, gear stick has very minimal play. (120,000k)
ecu - $550 pickup or postage
gearbox - $1100 pickup only
Northern suburbs of Melbourne
call chris on 0431613540
Cheers guys
isn't nistune ~$400 new? ..
Im selling the whole package, nistune boards are $420 from website, you then need to integrate it into a ecu such as a z32 or r32 ecu,
(z32 have VCT functionality) and then upload a map into it, or custom tune.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
