hi i recently hit a curb sideways and the only thing that bent was the left rear bottom arm that shaped like a triangle, so replaced that with another stock one, and the wheel is still on the piss bad!!
before
with the new arm in
i have adjustable rear camber + rear toe arms, other than that its factory and from what we can see nothing else is bent.
how do we get the wheel back to normal??
there is a camber arm (runs east - west) and a traction arm (the one closest to the front of the car)
from the pics it looks as the traction arm is too long so if its still one piece i'd say you've possibly bent the mount on the subframe..
that or your hub is bent
Bent subframe is odds on favourite.
Agreed
n even if it isnt, the pain of going through one by one and replacing bits that might be damaged (camber arm, trction arm, hub, diff etc etc) means it will probably best to just get a new subframe and all attachments and do a total swap.
Perhaps first thing is to go to a suspension shop like pedders and get them to have a look n see if they cant offer any guidance as it would be a bugger to replace the whole thing if it didnt need to be.
But judging by the look of the bend n break in the subframe mounting point for the trailing arm you replaced- the subframe probably is farked...
Also dont be surprised if your coilover if also in the f'd category...
Good luck
Edited by jjman
Take off your knuckle and im betting youve bent the tie rod mount thats why your toe is stuffed and youve probably bent the shock mount aswell, new knuckle will fix it but if you want to be sure take it off and compare to other side.
got a full alignment done yet to see if it all good?
Also check the hub n diff bearings after a drive n make sure that they are all good too...
final thing to check would be doing an accelration in 1st gear n make the wheels spin n see if it axle tramps. If it does also means some else isnt quite right.
hopefully u have it sussed tho! :thumbsup:
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
