  • Replies 3.5k
loving that album, good choice mane :D
I've got it on order, it really does look the goods! (And how awesome is the artwork?)
NY state - Nas
Quality track! Many believe Nas' best song from Illmatic, not sure if I agree though...
Currently listening to "Rivers of Blood" by Wu Tang Clan Feat. Kool G Rap (U-God's hook is the bomb!)
