Hey guys, hopefully somebody can help me, Ive tried on another forum but might be a bit more more knowledge here.
I recently had my s2 RB25DET and Apexi SAFCII wired into my VL commodore... the problem is that i need to do the initial set up for the safcII.. ive read thru the manuals i have here but its no use to me, tried google but there is to many mixed answers there, can somebody help me do the initial set up so that i can drive it around on stock boost for now? (no corrections/tuning or anything.. just set it up so the car runs using stock ecu/ % / etc) till i can get it on the rollers with a wideband.
Also can anybody recommend a place in brisbane that would do a good job of tuning it for me? (closer to the sunshine coast if possible) {mods are ; safc2, fmic, pod, cai, 3" zorst, hi flo cat, boost tee set 12psi, walbro 255, drift fuel press reg, platinum plugs gapped}
any help would be much appreciated.
cheers - mic
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/
I had the basic version of the SAFC on my RB25DET and don't know what the SAFC2 looks like but it should be obvious how to set it to zero which is where you would start. Select the car type and sensor type (hot wire) and set it to zero.
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6569308
no..it does not appear to be as simple as that but cheers anyway. have to set knock, tps, In:/out: lo%/hi% etc etc, was hoping somebody is familiar with the unit or done it recently. really need a "step by step" everybody I talk to / read says different things and its confusing as hell.
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6569470
Thanks bitsushiti, Ive had a look there,( I have the actual manual with me) it just doesnt explain a whole lot for me.., it has been used breifly in another car.. so basicly it needs to be reset and "initial setup" performed again,..problems im having is:
- im a noob kent with this unit... ive read the manual.. think i have it down.. go to do it and im a moron at using the thing. i just wanna get this initial set up done so the car can get a bit of a shakedown and be driven to where its getting tuned (2hr drive from my house) .. way to exxy on a towie and i want to know nothing is leaking / give it a good run & change lubes etc before it cops a flogging on the rollers as the engine has ran for about 10 miniutes in the last 12 months... its been a long winded build..
im hoping i can get this set up on my own but if anyone lives on the sunshine coast and is capable of doing it i am willing to pay fuel money + carton or $$ or car parts etc etc.
Edited by 25vlt
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6569596
kiwirs4t - thats probly true, but if you were going for a tune imo wouldnt you want to know your car is running right to start with? i mean it would be much more expensive to tow it down there and then waste hours & $$ on the dyno fixing little bugs.
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6570346
Quite right.
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6570611
I had another look around, apparently you can reset to factory defaults by going to the main menu, selecting 'etc' followed by 'init' or 'initialise'. Note this is for the first SAFC, not sure if same applies for SAFC2...
will try that this weekend. cheers
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6574182
did that, car seems to run fine, but it is displaying a correction... like 2.6% at idle and goes up with the revs.. would have thought that it should be 0% as there should be no tune/correction yet?, also didnt run it long enough to get it hot to set the knock so.. knock displays at 0 , is that ok for now?
https://www.sau.com.au/forums/topic/411065-rb25det-safc2/#findComment-6579173
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
