Hi guys looking to replace my engine mounts including gearbox mounts on the 33. Been looking around at some and notice that somem of the mounts ive been looking at apear a little bit different to mine. For example the driverside engine mount on my r33 is round. And the ones ive been seeing on ebay are sort of square or rectangular. Does this matter?? they are listing them for r33. Also will engine mounts from other rb models suit the 33 for example vl? or r 32? like to get these mounts sort asap because everything i see on ebay is quite exspensive for second hand and if its not second hand its nismo mounts which i really dont need its not like im running 500-600hp. Any info would be greatly appreciated.
https://www.sau.com.au/forums/topic/411110-r33-s1-rb25det-engine-mounts/
You NEED R33 engine mounts, yes they are different to VL's, R31's, R32's. Im not sure if they are the same as an R34 or not.
The rectangle ones you have seen are to suit an R31 and or R32. You do not want these.
If they are listed as being R33 but have rectangle ones in the picture, its highly likely that the picture is just for illustration purposes only.
But as always, you should be careful which ebayer you buy from.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
