The first time? It will take a few hours I think. It is made difficult as the aircon condenser is hooked into the bottom of the radiator.
Great... maybe I should get a new radiator now. I need to regass the air con and replace the belt, and get the bypass kit, and I've got a Nismo thermostat here waiting to go on when I replace the radiator.
Might be worth getting it over and done with before the stock one dies, and I can keep it as a spare.
lol you sound like Leon!
I figured the thermostat would be harder to get locally than a radiator, so I needed one on the shelf!
There was method to my madness...
Plus, my shelf is starting to get emptied, so need to find stuff to fill it up again! :D
In all seriousness though, I've read enough on here to have me a bit nervous about the radiator, so I have been tempted for a while to replace it before it dies, probably with the Mishimoto.
Managed to find that extra time this afternoon, the sensor was disconnected (and full of JDM fluff); I now have cold air again! +1 reps to both Scotty and Iain for identifying the problem so quickly :cheers:
in case it helps anyone, heres the location of the various sensors etc for the M35 air con
  • Thanks 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
