Heya, I've got a silver, manual series 2 R33 Skyline for wrecking here in Sydney. It's been hit at the rear, so the boot, tail lights, rear bumper are damaged. The front end and everything else is all good though, almost everything is listed up here including the mods it had
I can post almost everything here to anywhere in Aus, or pickup is fine in Sydney. Just PM me or reply here if you're after any parts
post-35556-0-36032100-1349925628_thumb.jpg post-35556-0-21617900-1349925620_thumb.jpg post-35556-0-12559200-1349925595_thumb.jpg
Aftermarket parts:
Apexi Power FC & hand controller to suit R33 Gts-t rb25det, immaculate condition - $1000 firm
FMIC & piping kit, suits R33 Gts-t. Good condition, includes all pipes and hose clamps - $300 - pickup only
SF-DIS-005 Splitfire coil packs, suits S1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Apexi AVCR electronic boost controller - all hoses, solenoids, controller mount, etc included. - $350
Oil Catch can - $60
Z32 AFM and matching plug, as new condition - $200
Auto Meter boost and air fuel meter gauges in custom DIN mount - $150
19x8.5" and 19x9.5" HP Design wheels and tyres. Great condition all round, only a few small gutter marks on one of the wheels
Fronts are 19x8.5, +38 offset, rears are 19x9.5. +38 offset, all are 5x114.3. almost 3.5 inches of dish on the rear wheels
Good tyres all round, fronts are 235/35 Kuhmo approx 40-60% tread and rears are 275/30 Nankang 70-90% tread - $1200 ono for the set, can ship them anywhere
Front strut brace - $75
26/27mm Nismo front swaybar - $150 ono
HKS turbo timer - $50
Adjustable castor rods - $100/pair
slotted/drilled rear rotors, lots of meat left - $150
k&n pod filter - $25
The car also has an aftermarket rear swaybar and bigger injectors, but i'm yet to pull these off
Standard parts:
The engine has 89,000k's on the clock and was running perfect. I did a compression test last week and it was all good - approx 155-160psi on all cylinders - $1000 ono for the bare engine
5sp manual Gearbox is also in lavish condition. Includes a short shifter - $1300 for the box, or I can sell as a complete manual conversion for $1600
Exterior Stuff:
Series 2 headlights - $200 each
Series 2 bonnet, some stone chips - $200 - pickup only
Series 2 reo bar - $150
Front guards - $75 each
Front bare nose cut/radiator support - $150
Front bumper, has a cracked spot near where the #plate sits, and some stone chips. Includes lower lip and indicators/foggies - $250 pickup only
S2 grille - $60
Side mirrors - $40 each
Trial (i think) sideskirts, good condition, no cracks - $150 ono for the pair. Pickup only
Engine bay stuff:
Aircon condenser - $125
S2 Rb25det engine loom - $150
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $100
Engine Mounts - $75/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Brakes/driveline:
Front calipers (painted red) - $280
Rear calipers (painted red) - $140
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Adjustable castor rods - $120/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $140 pair
Handbrake drum assembly incl cables - $150 pair
Manual (4.11) ABS rear diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Full set of standard suspension (with KYB rear shocks)- $150
Interior:
Complete set of floor mats, good condition - $80
Complete boot interior, good condition - $80 (pickup only)
S2 Front seats, Great condition - $150 ono
Complete set of S2 door trims, immaculate condition (x4 pieces) - $100
Passenger side window motor - $50
Drivers side window motor - $100
Driver side window switch - $75
dash instrument cluster, approx 89,000km, all working - $120
S2 airbag steering wheel, Great condition - $200
Instrument cluster surround (S2) with all switches/vents - $100
Manual gear stick surround (S2)- $50
Centre console, with good lid/latch - $50
Seatbelts (full set) - $100
Ignition barrel + door barrels & key - $90
  • Replies 43
Hey mate,
How much for the top radiator mount brackets with grommets post to Canberra 2911?
PM sent !
adjustable castor rods are they the rubber bush type?
Sorry, no rubber, they're all metal
hey I am interested in the drivers side window motor.
Where r u located in Sydney?
PM sent
does the intercooler piping suit r34 gtt?
Probably not sorry, there are likely some small differences. I think only return-flow FMIC kits fit both r33/r34
Hi, do you have the front bumper/fender liners? the black plastic bits that sit in the wheel arch, and behind the front bumper?
If you do, please PM me, or SMS 0401 549 030.
Thanks,
Ben.
Thanks,
Ben.
yup, PM sent
interested in Manual gear stick surround can you ship to 4802?
yep, PM sent !
floormats, front reo, door locks & grille sold, front bar & gear surround sold pending payment
and a couple more pics:
GSS-341 walbro fuel pump in R33 cradle - $100
post-35556-0-78377200-1350210032_thumb.jpg post-35556-0-05036300-1350210184_thumb.jpg
Is the drivers side window switch 11 pin??
hey, it's a 12-pin switch - theres a photo of it in the first post
cheers
Wheels pls. Can pick up asap. keen!!
Pm sent!!
Or sms 0468744534
Cheers
Edited by R34NeoGTT
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
