  • Replies 43
hey mate interested in motor/gearbox package please pm me number
cheers
PM sent !
Hi mate, I am interested in the engine if its still available. Thanks
PM sent
How much for the frontbar and the garnish between head lights posted to 2620 queanbeyan
Sorry mate the front bar and grille are both sold
I want that PFC but i don't have the cash at the moment! sell it to me and I'll pay you off weekly XD
Haha, if you're serious I would take a non-refundable deposit on the PFC and i'll hold it (for a while) for you till you get the full amount
i am but I'm better off to save my pennies :( and just buy one when i have the dosh..
No worries
Hi mate just checking if gearbox still available if so call or sms me on 0412392232 thanks Tom
SMS sent !
hey im very interested in the FMIC , to fit it do you have to cut a hole in the body of the car tho?
text me 0407604714
Sorry mate I sold the FMIC last weekend
  • 3 weeks later...
Hey mate, just wondering if you've still got the ignition barrel/key barrels and the RHS door trim and or window switch. Cheers.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
