For sale are some Genuine R33 RB25DET parts that came off my Series 2.
Instrument Cluster with 146k, all working fine except the Tachometer doesnt like telling the RPM all the time, sometimes jupms around, not sure the problem but it works sometimes. could be a easy fix. $60 ono.post-86950-0-20785000-1350019285_thumb.jpgpost-86950-0-61380800-1350019306_thumb.jpgpost-86950-0-28863200-1350020303_thumb.jpgpost-86950-0-81577700-1350019856_thumb.jpg
RB25DET Wastegate actuator, Good condition works perfectly fine. $35 ono.post-86950-0-45510200-1350020053_thumb.jpg
R33 Series 2 / R34 GTR coil packs, great condition near new with no spark blowout at high rpm, Genuine Nissan. $220 ono.post-86950-0-58036900-1350019470_thumb.jpgpost-86950-0-85019000-1350019523_thumb.jpgpost-86950-0-56335300-1350020219_thumb.jpgpost-86950-0-97898900-1350020149_thumb.jpg
R33 RB25DET standard blow off valve / BOV, awesome condition works fine. $30 ono.post-86950-0-65599300-1350020123_thumb.jpgpost-86950-0-68335000-1350020092_thumb.jpg
R33 RB25DET stock dump and front pipe, has surface rust no leaks/ holes/ cracks etc great condition. $30 ono.post-86950-0-71191300-1350020351_thumb.jpgpost-86950-0-11625500-1350019626_thumb.jpgpost-86950-0-57725500-1350019905_thumb.jpg
R33 RB25 Slave cylinder, great condition holds pressure works fine,no leaks. $25 ono.post-86950-0-38616600-1350019601_thumb.jpgpost-86950-0-27328300-1350019788_thumb.jpg
R33 RB25 Clutch Master Cylinder, awesome Condition, Had reco on it when was on my car. works great holds pressure no leaks $50 ono.post-86950-0-96454200-1350019560_thumb.jpg
R33 Rb25 Thermostat, Works great pluger and spring work great, no faults. $25 ono.post-86950-0-80174700-1350019731_thumb.jpgpost-86950-0-36169100-1350019654_thumb.jpg
Located in Brisbane Northside, can be picked up at either Warner or my workshop at Virginia. can post smaller items at buyers expense (obviously). Im open to offers pm me for any more details. inspections welcomed if wanting to have a look at parts.
https://www.sau.com.au/forums/topic/411403-r33-rb25det-rb25de-parts-qld/
  • 3 weeks later...
will check to see how much it would cost for freight and will let you know as it is quite a bulky/long unusual shape item lol
Hey would u take 30 delivered for the dump n front pipe im in townsville
sorry but with freight cost i wouldnt make any money thanks for interest tho, make offers peeps
  • 1 month later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
