For sale are some Genuine R33 RB25DET parts that came off my Series 2.
Instrument Cluster with 146k, all working fine except the Tachometer doesnt like telling the RPM all the time, sometimes jupms around, not sure the problem but it works sometimes. could be a easy fix. $60 ono.post-86950-0-20785000-1350019285_thumb.jpgpost-86950-0-61380800-1350019306_thumb.jpgpost-86950-0-28863200-1350020303_thumb.jpgpost-86950-0-81577700-1350019856_thumb.jpg
RB25DET Wastegate actuator, Good condition works perfectly fine. $35 ono.post-86950-0-45510200-1350020053_thumb.jpg
R33 Series 2 / R34 GTR coil packs, great condition near new with no spark blowout at high rpm, Genuine Nissan. $220 ono.post-86950-0-58036900-1350019470_thumb.jpgpost-86950-0-85019000-1350019523_thumb.jpgpost-86950-0-56335300-1350020219_thumb.jpgpost-86950-0-97898900-1350020149_thumb.jpg
R33 RB25DET standard blow off valve / BOV, awesome condition works fine. $30 ono.post-86950-0-65599300-1350020123_thumb.jpgpost-86950-0-68335000-1350020092_thumb.jpg
R33 RB25DET stock dump and front pipe, has surface rust no leaks/ holes/ cracks etc great condition. $30 ono.post-86950-0-71191300-1350020351_thumb.jpgpost-86950-0-11625500-1350019626_thumb.jpgpost-86950-0-57725500-1350019905_thumb.jpg
R33 RB25 Slave cylinder, great condition holds pressure works fine,no leaks. $25 ono.post-86950-0-38616600-1350019601_thumb.jpgpost-86950-0-27328300-1350019788_thumb.jpg
R33 RB25 Clutch Master Cylinder, awesome Condition, Had reco on it when was on my car. works great holds pressure no leaks $50 ono.post-86950-0-96454200-1350019560_thumb.jpg
R33 Rb25 Thermostat, Works great pluger and spring work great, no faults. $25 ono.post-86950-0-80174700-1350019731_thumb.jpgpost-86950-0-36169100-1350019654_thumb.jpg
Located in Brisbane Northside, can be picked up at either Warner or my workshop at Virginia. can post smaller items at buyers expense (obviously). Im open to offers pm me for any more details. inspections welcomed if wanting to have a look at parts.
https://www.sau.com.au/forums/topic/411403-r33-rb25det-rb25de-parts-qld/
  • 3 weeks later...
will check to see how much it would cost for freight and will let you know as it is quite a bulky/long unusual shape item lol
Hey would u take 30 delivered for the dump n front pipe im in townsville
sorry but with freight cost i wouldnt make any money thanks for interest tho, make offers peeps
  • 1 month later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
