Honestly, if you are sick of the sound I know where your coming from, thats why I changed mine
And it doesnt really matter what you choose as long as its a plumback, there are to many issues with the Atmo BOV's (Search and you will find) so make sure you get a plumback
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579403
Yea Cal, pretty over it, its a bit boring i guess lol
I have heard about a few good read ups on the Gtr ones so might give one a go.
And remember dude the coast is still pretty hostile with the boys in blue so keep it legal :thumbsup:
Maybe see you on Sunday?
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579462
are the stock ones good enought for gt30's? must be alot of air to move for the blow off valve.
when i back off the throttle im getting a quietish zututututu...
Edited by SliverS2
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579473
Mine failed a long time ago, it was sticking open and not getting boost etc..... Not commen from what ive seen but made a big difference when i put the new plumback on and got some zutututu action too :P
Yep ur not wrong Mat, thats why im trying to keep things looking stockish i guess ha
Yea man possibly, i will let u no during the week for sure, cheers
Yeah good plan, keep out of trouble!
Let me know if you can come say G'day and meet some of the members even if you cant make the run :)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579484
AFAIK the stock BOV works fine on most Gt30 series turbos, plenty of people running GT3076's etc with stock/GTR bov's
Mine is a Greddy Type RS Rip off, but im Considering getting a genuine. So if that happens I will probably sell mine which has a custom plumback adapter on it (as the genuine one doesnt fit and the rip off doesn't come with one)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579490
Haha im hoping so. Yeah man for sure im pretty keen, hopefully install my coilovers this week, would be sweet to give em a run
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579535
I think its the pressure that is a concern for them sealing, and they do flutter to a degree so its obviously a lot of air but alse depends on the position, factory position is pretty good as its close to the TB, the GFB one i have now still flutters a bit even on soft setting, but its a LONG way from the TB.....
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579536
Mine went on on the weekend, have a look -
http://www.skylinesaustralia.com/forums/topic/358438-34geeteetee-daily-track-project/page__st__400
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579537
Thansk mate, if you dont make this cruise dont worry as we plan on doing stuff at least monthly! November will be an exception as a couple of us are entered in the SAU Nats :D
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579547
Sweeeeet, sounds good man!
If you join as a member there is a members section with a Newy/Coast chat thread where questions like these will be answered by the guys for ya :D
Plus for the price of membership you get a heap of value, stickers, lanyard, shirt and discounts off purchases at some places AND it give you better pricing for events etc :yes:
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579557
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
