I bought a power fc which came out of a series 2 r33, plugged it in. But it doesnt power up (hand controller doesnt turn on, fuel pump doesnt prime, no injector pulse etc). Plugged the standard computer back in, and it works fine.
The reason why I bought this power fc is because the majority of people say that series one and two both run the same computers.
Today i got my power fc checked by a profesional to see if it shit itself, but he said it's sweet.
Heeeeeeeeeeeeeeeellllllllllppppppppp meeeeeeeeeeeeeeeeeeeeeeeeee!
That's the next step i reckon. Don't know if i trust the guy who checked it out, even if he is a "professional".
Got a guy at work that has a series 2 motor in his VL, and a mate with a series 1 r33. So i'll probably just give them a go. I dont reckon my wiring is wrong because the standard computer works fine, so it has to be computer related it would seem
What's your serial number? If it starts with ECR010 then it's series 2, or RB25 for series 1.
There is no s1 or s2 power FC, the one model suits both s1 and s2.
The ECR and RB25 codes simply determine whether it's an older model or newer (still old) model power fc.
Test in another car to make sure it's not stuffed, if it works then have a look at your wiring, check voltage at everything that should have 12v and make sure the earths are good. You could have a dodgy wire somewhere that's supplying enough power/earth for a standard ecu but not enough for the FC, they do draw slightly more power.
Oh, you may have one of the relays near the ecu missing.
Its strange but the standard ecu doesnt require this particular relay, but the pfc does. From memory I thinks theres supposed to be 2?
Its the eccs relay that u guys are talking about.
The ecu requires battery backup power and ignition power to 1 pin. Then the eccs relay is teased via a negative pin which inturn powers the eccs relay powering the next 2 power inputs into the ecu turning it on.
The reason for this is so when the ignition key is turned off the ecu can hold the eccs relay on to keep the ecu powered for 1 second to allow it to save data to NVRAM. This isnt detrimental to the stock ecu however with a power fc it wont store any changes in the tune without this happening.
Op try the ecu on a mates car first. If it doesnt work on that then it may be a faulty ecu.
I have just had this happen to me recently and a warranty claim has been started for the power fc
***UPDATE****
Power fc works perfectly on my mates VL with rb25det series 2.
I think you guys may be right about that relay. makes perfect sense.
I'll let you's know how i go
  • 1 month later...
Compare these two diagrams i got from this website. Pin 17 is one of them. Ignore the fact that it says R32. Apparently r32 and r33 series one are the same, And R33 series 2 are the same as R34 series one.
http://wiki.r31skylineclub.com/index.php?title=Pinouts
My auto electrician did it so I'm not exactly sure, but i just checked the diagrams to make sure he wasn't bullshitting me to get some extra cash. Pretty sure he said there were 2 wires that needed swapping around
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
